Electronics; how much is too much?
BroncoMike
Upper Norwegia
'71 Bronco, '02 Excursion
Mine Went 90mph Regularly On The Beach Or On The Highway Never Wrecked Was A Kid Then But Went Fast And Stayed Alive
Guidr3
Louisiana
F 150
Num Nuts Are The Dangerous Ones At 50 MPH
Nickp
Nick
Phoenix
“Survivorship Bias”
The ones who didn’t survive aren’t here to talk about it.
Ole Skool Bronc
Ole Skool Bronc
CJ3B Willys, 1G Bronco, TJ Jeep, Dodge Diesel.
Had my 72 (not stock) Bronco topped out at 117 mph. It didn't feel sketchy, but what did I know at 20 years old.
Ole Skool Bronc
Ole Skool Bronc
117mph any film to confirm?
Oh yeah, I had my 40 year old iphone on record, I'll see if I can find the vid.
The EB speedo only goes to 100 mph, my needle was pointed almost straight down; approx 117
While you're in a state of disbelief; I'll add; on dry pavement it could pull the right front tire off the ground if you launched it.
OX1
jackson nj
59 Brd, 70, 78, 79 Brncs, 84 LTD 331, 86 Cpri 5.0 Trbo, 17 Fsion Sprt, 21 GT 500
Steady state highway I had mine up to about 80 with flexy 3.5 lift, 33's, no top/doors
and no sway bars. Not something I'd want to do a lot, but it wasn't as horrible as I thought.
That was stock 302/4bbl/intake/headers/duals, stock 3.5 gear, T-18 4spd, sea level, flat 2 lane highway
and I don' think it had that much more in it really. That brick sucks a lot of power on the
highway at higher speeds.
TeocaliMG
Plymouth Michigan
And I can pull a wheelie with a skidsteer if I lift the bucket a little bit ;)
nameuser
North of Scipio
67 Halfcab
Had a buddy swerve to miss a deer and rolled in a field. The roll over didn't hurt him, but the tool box, handyman, and elk antlers darn near killed him.
By the way......don't grab the roll bar as you go over.
Ford Bronco Electronics; how much is too much? Darwin finger 1
Guidr3
Louisiana
F 150
I’am sure Ford is aware of rollover possibility in smaller suv’s I trust that they will build the bronco as safe as possible.
OX1
jackson nj
BroncoMike
Upper Norwegia
It's literally a $0.00 solution. Similar to critical computing, you don't allow an untested/unproven update.
Stampede.Offroad
SD
junk
Who says you're going to get a choice on the matter?
If you have to opt-out every time you get in your vehicle for other features, they can just as easily make you dig through menus and opt-out for updates before every shut down. Then one day you forget, are in a hurry etc. and get stuck with it.
