Bonnie & Clyde
Cory
Carson Valley NV
2024 Two door Big Bend Sasquatch Azure Gray
So does this only affect the 2.3? I have the 2.7 (22 Wildtrak) and haven't seen this recall. I do use my block heater often (sub-zero temps often here). I let it run for 4 hours before my commute to work. Should I be concerned?
I think its 2.3 only but Im not a doctor
Bob
Illinois
Mustang GT
I have a 22 7MT. Brought it in for the engine block heater recall. The parts are not available, so they "disabled" the block heater until they figure it out. This repair is not rocket science. The block heaters are currently available on about all Ford vehicles. When it was working I appreciated that the oil temps were already in the 85-100 degree range when starting. Warm air was available immediately. As the heater heats the coolant directly, not the oil, I suspect the coolant was even warmer than the oil.
CalvinT
Calvin
Phoenix, AZ
I don't understand. The simple way too "disable" the block heater is don't plug it in. They're all disabled until plugged into 120 VAC.
Bob
Illinois
Mustang GT
Apparently, it can start a fire, so Ford doesn't want anyone to mess with them at all.
CalvinT
Calvin
Phoenix, AZ
Cutting off the plug is the only way to really disable it.
CalvinT
Calvin
Phoenix, AZ
Zombie Salamander
numerous Ford vehicles 1970's to present
is there an aftermarket alternative for the faulty engine block heater that could be installed so that we could maintain our functionality? Preferably using the factory install location?
Ducati1098
A new block heater will be supplied/installed by Ford under a future customer satisfaction program when parts are available.
Bonnie & Clyde
Cory
Carson Valley NV
I am approaching this as a hurry up and wait recall. Maybe in the summer dealers may have the parts and practiced on someone else before I call the dealer to fix mine.
ac360
Here/There
None
I have a 23' Badland Sasquatch with the block heater. No recall for my VIN on NHTSA's website. Looks like not all affected model year Broncos are affected by this recall.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Which engine do you have?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
my 23 badsquatch w. the 2.3L/7MT has the recall notice
