Rootdog
Rob
Maine
Ram 2500
There are these new inventions called garages that are even heated I heard.
A block heater does nothing to get the transmission or diff oils up to temp. A gas engine will fire up in pretty extreme weather. I've driven them above the actual Arctic Circle in Norway.
Garages are super cool and can be heated I hear but not everyone has access to garages. Norway sounds awesome, heated garages for everyone!
AK SNO RIDER
Ty
Alaska
WTF.. 8 open recalls on my FE. Every time I take it to the dealer they are not ready/don't have parts/forgot why I made an appointment.
Engine Valve, Driveshaft, Camera, Fuel pump, Block Heater, shocks.
Its never left me stranded, but this is getting ridiculous.. I guess I should be thankful that I got most of the water leaks fixed early on.
The number of recalls I've had on my FE is almost comical. Of course the only one I care about is the fuel pump and there's still no fix for that...🤦‍♂️
Bonnie & Clyde
Cory
Carson Valley NV
2024 Two door Big Bend Sasquatch Azure Gray
Heating your engine oil before driving off in these modern TURBO motors is good thing. Its not good on the turbo to start up cold and just drive off. Engine block heaters help with that as well as the other ones mentioned.
Steve_In_29
St Johns, Arizona
2023 Bronco 2D, 1973 Bronco, 1999 Ranger, 2007 F350
Even if unheated the garage will keep the vehicle warmer then being outside.
They drove like maniacs on the ice covered roads along side the fjords.
Drinking and fucking were about all there was to do in winter. Local girls with a case of Mack'Ol would come out to our bivouac sites.
Steve_In_29
St Johns, Arizona
Now that is a valid point.
chtucker
Kirkland, WA
FJ Cruiser
And my fuel tank is buried underneath my Next Venture Motorsports skids.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Q1 2026 kind of sucks...no block heater this winter. If I need to go to Manitoba this winter it will cross into the "really sucks" realm.
After three* winters of using the block heater daily, here in MB…. I’ll take my chances. If she’s burns, at least she’ll be pre-warmed for me
*edited for bad math
Bonnie & Clyde
Cory
Carson Valley NV
After two winters of using the block heater daily, here in MB…. I’ll take my chances. If she’s burns, at least she’ll be pre-warmed for me
What motor do you have?
Bonnie & Clyde
Cory
Carson Valley NV
Good to hear they aren't just burning down left right and center. Ill probably use mine a few times this winter. I don't get great white north cold but single digits are common. Ive got the 2.3 as well with a recall notice.
AlienHunter
Alien
Mid Atlantic region
Why does anyone that doesn't live above the arctic circle need a block heater on a gas engine?
A diesel like my F350 I can understand but on a gasser what's the point?
Apparently you’ve ever been to Iowa or Minnesota in the winter.
bobogto
Chicago
M5
Did a block heater touch you inappropriately? :LOL: Why such a fight against it?
Drawback of an internal combustion engine(regardless of fuel type gasoline, diesel, LPG, methane...) is that they operate at it's best at a certain temperature and that temperature is never what the ambient temperature is. Manufacturers have been designing and implementing ways and complex components to achieve a quicker operating temp for years. Yet you argue and bitch about probably the simplest one out of them all.
bobogto
Chicago
M5
I got a notification that "remedy is available". Does anyone know the updated part number and if it's available at the counter for any Joe Shmoe to buy?
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
So does this only affect the 2.3? I have the 2.7 (22 Wildtrak) and haven't seen this recall. I do use my block heater often (sub-zero temps often here). I let it run for 4 hours before my commute to work. Should I be concerned?
