EZPZ Tire sizing calculator
Wanted33
Down south in Dixie
I don't know if this calculator has been posted. For those like me that are wondering what size tire you want on your Bronco here's one that wraps it up in a neat package. Just put your factory size in, and them the sizes you are thinking about, and it shows you the difference in 5 categories.
https://tire-calc.com/comparison/255-70-r18-and-265-75-r17-inch/
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
MyATV
ATL
NotApplicable
BEVs
Do any of them calculate how wheel width impacts the dimensions? Not wheel diameter…
can someone give me an example of a 17” “true 35” tire size, as I’ve heard many refer to the SAS tires as “not true 35s”? The first link says 305/75/17 is exactly 35”, but tire rack shows no tires for this
ilbastarge
Northeast
Tesla X
35*12.5*15 for example
Groundhog
Ozark
'22 Wildtrak, '21 OBX
Here's one I've used several times in the past when sizing after market wheels/tires. Allows you to compare current wheel setup to new wheel setup -- https://rimsntires.com/specspro.jsp
kodiakisland
Arkansas
This is the one I use: Tire Size Calculator - Compare Tire Sizes | Tacoma World
Remember, these are just estimates. Tire manufacturers are somewhat random in how accurate their sizes are, plus, the actual sizes change a bit based on the width of the wheel. You still need to look at the manufacturers specs to see what the actual size is they claim, even though it's not always accurate either.
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
the 315-70-17 is 34.4" per the chart but the Goodyear Wrangler MT lists 34.7, CooperDiscoverer 34.6 and others is a range from 34.4 to 34.7. The calculation is an estimate for a generic tire size with different manufacturers actually building tires to their own size. Inflation pressure also effects tire diameter.
HoosierDaddy
__ Eric
Look at the offset calculator at the tiresize.com site.
https://tiresize.com/wheel-offset-calculator/
HoosierDaddy
__ Eric
Here's a Base 16 vs a 285/75-17 on +25mm wheels.
That info on the right is precious.
Speedo error is listed below but not shown on this screen cap.
Ford Bronco EZPZ Tire sizing calculator 1626062202226
Mjtermini
2022 2DR Badlands
