Factory Roof Rack- does it make it harder to remove top?
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
My 2 door has been built! ETA 7/25. I have factory roof rails- do they make it difficult to remove the hardtop?
TIA,
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
No, you have to take it off to get the top off. I can take it off in about 5 minutes!
MayhemMike
Mercury
Not more difficult, just additional time to remove it in order to get to the top. First time, it takes about five minutes to remove the rack.
da_jokker
Jeep Wrangler JKUR
I believ you can remove the front panels with the rack on, But if you want to take the rear shell off, you have to remove the rack because it's attached to it.
Go Devils
Reed
I have the factory roof rack on a 2-door. While I haven’t taken the full top off, I’ve taken the front panels off many times. It’s tight but it can be done. I would prefer taking the front panels off without the roof rack as I’m worried that the tops or the painted areas will get scratched from the maneuvering. Just my .02.
9100toZero
Pensacola
2022 Bronco Wildtrack
I have 4 door with hard top and factory roof rack. The front seat roof panels are definitely removeable but ya got to negotiate the clamp and slide roof back an inch or two to clear the rack and opening. I VE done it a couple times. Much easier with roof rack off (currently).
Fly
MA
Subaru Outback
Can you remove the roof rack and drive around without worrying about rain getting in any mounting holes? Im considering ordering the factory roof racks and only putting them on when needed.
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
The factory roof rack leaves no mounting holes on the top. It clamps to the cutouts on the side. The front mounts to the accessory mount above the windshield and comes with the caps in the glove box. I took mine off after the first day and hung it on the wall of my garage. I just pop it on when I'm loading out to go hunting. Pretty simple.
Fly
MA
Subaru Outback
Perfect, that's exactly what I am planning as well. Thank you
9100toZero
Pensacola
I have 4 door model. The 2 front panels are removable but it takes a little finesse. There is a centering pin on the top and a corresponding receiving hole on the truck. You edge the panel towards rear and gently walk the centering pin around the receiving hole and the once cleared the panel slides right out.
