- factory wheel + tire = 57.5 lbs
- factory tire 30" dia, Bridgstone Dueler H/T 255/70R16 = 31 lbs
- factory steel wheel: 26.5 lbs
- wheel offset: 55 mm
Sasquatch
- factory wheel + tire = 87.5 lbs
- factory tire 35", Goodyear Territory MT LT315/70R17 = 52 lbs
- factory wheel: 35.5 lbs
- wheel offset: 30 mm
- factory wheel + tire = 58.25 lbs
- factory tire 32" dia, Bridgstone Dueler A/T 255/75R17 = 35 lbs
- factory aluminum wheel: 23.25 lbs
- factory wheel + tire = 74 lbs
- factory tire 31.6" dia, General Grabber A/TX 265/70R17 = 44 lbs
- factory steel wheel: 30 lbs
- wheel offset: ____mm
- factory wheel + tire = _____ lbs
- factory tire 32.1" dia, Bridgstone Dueler A/T HRS 255/70R18 = 39 lbs
- factory wheel: _____ lbs
Badlands with bead locks
- factory wheel + tire = 80.3 lbs
- factory tire 32.8" dia BF Goodrich KO2 AT 285/70r17 = 50.3 lbs
- factory wheel: 30 lbs
Badlands without bead locks
- factory wheel + tire = 78.3 lbs
- factory wheel: 28 lbs
Wild Track
- factory tire 34.4" dia, Goodyear Territory MT 315/70R17 = 52 lbs
Add the missing info if you have it, other models if you have it, and no guessing, actual measured or manufacturer's specified weight please!
Sasquatch
Wild Track
