The removable top is the only draw for me. What they should have done is made a removable top that didn't suck.
I did this to mine back in November still working.
Just installed this hack tonight. Different brand wraps off Amazon. You win the chief engineer award! It worked like a dreamā¦ no more CLACK, CLACK CLACKING! Was driving me out of my mind. Thank you!
This completely eliminated the noise for me and was very quick and easy. Make sure to use some pliers to gently push the tubing on all the way. Even if it doesnāt last forever it takes less than 10 minutes to do it over again.
The noise is caused by the pin over the driver/passenger seat rubbing on the side of the pin. The sleeve adds a buffer between the hard plastic pin and the metal bracket. The front does not appear to be a problem.Just installed the same rubber sleeves. From what I could tell so far, it works. But then again it's 60 degrees. I'll take a better listen when its closer to freezing temps outside, as that historically brought out more rattles.
FYI upon taking a very close look with a flashlight - the rubber sleeves on the mid panel pins appear to be useless. Let me try to explain - All the pins have a āflangeā at the top where it flares out some, and its too wide to get the sleeve over the flangeā¦unless you use a size up and heat shrink it (which I did not). On the mid panel pins, the bracket is higher up in relation to the pin, and the bracket is inline with the flange area, so my sleeve actually sits a hair below the bracket and doesnt provide any protection between the two surfaces that would rub. Whereas on the front panels, the bracket sits lower in relation to the pin, so the sleeve does provide coverage. Thankfully, the mid panel pin design has a rubber gasket above, whereas the front panels do not. Likely the culprit of the issue in the first place.
Photos below of mid panel pin then front panel pin. You could see how the sleeve for the mid panel doesnāt provide coverage. Iām not hearing any pops which is good. I suppose if I do hear pops from the mid panel I could go a size up on the sleeve and shrink it around the upper flange of the pin. But itās really the front panels that were the problem and now seem to be fixed.
Wrap them in electrical tape. It wonāt fall off.Sadly, the heat shrink sleeve just fell off. Even with some light heat applied to it to get it to be a tight fit, it felt off in several places and doesn't seem to be the long term viable solution (for me).
Also, I think I'm still hearing a rattle, which probably isn't from my hard top.
what size did you use?Sadly, the heat shrink sleeve just fell off. Even with some light heat applied to it to get it to be a tight fit, it felt off in several places and doesn't seem to be the long term viable solution (for me).
I bought the same one from the O Reilly and used the same size as per the Youtube videowhat size did you use?
