Ford or FWP side steps?
WatchYourSix
NY
2020 Explorer ST, 2021 Bronco, 2022 Maverick
I seriously considered them but we get A LOT of salt on the roads in the winter and really worry about the electronics
I hadn't really thought of that but supposedly they're sealed well and the controller lives inside the vehicle I believe.
  • Like
Reactions: R11
webspoke
Stan
Pilot Point, TX
F450, GT350
I had amp steps on my grand cherokee. The controller is sealed and tucked away, but the step motors are not 100% sealed, and I had one that got soaked and corroded and would only function intermittently. Nice when they worked, but the mechanism and motors do not like very dusty, wet, dirty environments.
CARdiac
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
This is my concern...between heavy snow (I have driven through a good 32" in my H3) and a couple of water crossings on trails nearby and the copious amount of salt on the roads in the winter, I really don't want to have to worry about power steps.
Jv15
VA
VW
I just installed the OEM side steps on my 4-door base sas today mainly because my wife didn’t like jumping in. They are solid and seemed high quality, install was very easy took about 15 minutes total. 6 13mm bolts on each side into pre threaded holes. I liked the bronco lettering on the oem and not worried about ground clearance so they made the most sense to me. Both the wife and I are very happy with the results.
Ford Bronco Ford or FWP side steps? 2B2CF468-70A9-404B-85DE-2C48A54CDEA3
Ford Bronco Ford or FWP side steps? 9CB35499-BC4F-4F2B-8CF6-B54A2B12E8C2
5280Bronco
Denver
I'm also going to wait and see how much the RTR side steps/rails are once they come out.
  • Like
Reactions: R11
Mzekew
Nissan Xterra
Really appreciate you sharing. This is the best detail pic I’ve seen of OEM side steps to date, and they look pretty good! I’m considering using Ford Point to do the same, but haven’t seen them in person. Willing to post more close up and side view pics?
(Repost to correct janky formatting.)
goalie
CA, USA
2015 Jeep JK
I think one thing that would h
I think one thing that would help people is taking a pic from the inside as if you are stepping out of it. I drove one this weekend with steps and was noticing they are tucked in and hard to get your foot on from inside, very noticable getting out of the back. Maybe it doesnt matter as they are more used to get in, people can just "jump" down getting out.
Jv15
VA
VW
Adding more pics - @goalie you are correct in that they aren’t as helpful getting out unless you take your time and turn your foot a bit. I just skip them and jump/slide down a lot, depends how much of a hurry I am in. But getting in, which seems to be a majority of our use case, is good. I tried to take a few pics from directly above/down the side so you can see how much it sticks out.
Ford Bronco Ford or FWP side steps? 221128D7-4160-4972-A937-A76CE36F7677
Ford Bronco Ford or FWP side steps? C0106EA1-2416-48D0-8EA2-077A989E3AE1
Ford Bronco Ford or FWP side steps? D81A12BC-7411-4EC0-80D3-BC50A3D51E99
Ford Bronco Ford or FWP side steps? AAE37FDE-78E6-47A8-9349-439E26B872AB
Ford Bronco Ford or FWP side steps? C6B9331B-0B5C-49A4-B549-4B91C17CA68E
79BKO
Richmond Texas
79 Bronco, 21 Bronco Big Bend SAS
Its even Cyber Orange.
Sidesteps are absolutely brutal to your ground clearance. Keep that in mind if you plan on off-roading. Its the feature I like least on my Tremor and they would already be gone if I wasn't about to sell the truck.
With that said, go OEM. They are really nice looking and seemed really high quality when I used them in person.
This is what my wife uses to get into my 79 currently!
