Wilbur's son
Hesston, KS
2001 Ranger 4x4
Once it is locked the fob has to be right there with you to unlock.
So walking away with the fob in your pocket prevents entry once you lock the doors.
Plus a Farady pouch key holder for a little extra signal blocking.
  • Like
Reactions: GAN
broadicustomworks
Hanging Rock, North Carolina
Ford Bronco Ford's Cargo Area Enclosure with Fixed Lid - Installation Guide and Review 1F471DDC-C662-41D2-A68A-15A686401987
I love mine. Eventually I’ll figure out a way to quick release the front panel as well.
Glad it offers up a bit of security, blocks most of the precipitation, and cleans up the look.
Oddly enough I’ve picked up a total of .2mpg average.
Catatonic
Over there
Interesting. Had the truck a year and a half and learned something new. Sure enough, lock, walk fob into house and come back and doesn't unlock. Thanks.
GoVols
Atlanta
2022 Bronco
Aviator
Aviator
Detroit
youtube.com
2023 Bronco Raptor
Those little D rings on the top don’t bounce and rattle?
as Bulldogg915 said, tight, very tight - and no vibration or movement. 👍🏻
I installed the hinged version on mine and highly appreciative of the added security for both top-off and top-on instances. It was a bit of a PITA install, especially getting the final bolts attached from the rear-seat panel but eventually got it in.
The drawbacks are noticeable though.
First of all, I have a BRaptor which means that the lid doesn't really go up very high as the rear bar blocks it so I never use that functionality.
Secondly you can't fold down the panel against the rear seat in case you need to transport something long/large. Not the biggest issue but when you need the capability, you need it and don't have it.
The last item is that the lid blocks the space needed to use something like a TopLift Pro or RollNJack for easier removal of a hardtop. I have a camstrap system that I use in my garage but would prefer the ease of one of those tools but the lid simply blocks that functionality. And if I considered removing the lid to use the tool I lose all of the time and effort that it would provide by having to dissassemble and reassemble the lid.
One product that solves all of those issues is the Diabolical Slipstream as it's far more flexible in design. But I couldn't justify spending $1400 for that product when I got my Tuffy for less than $400 (found a significant discount code when I purchased). Diabilical has some discounts from time to time but still ends up well over $1200. I just can't justify that cost and then still needing to do some small mods to remove the rattling that the Diabolical product has with it's pin connector design.
Great points. Top removal and replacement is complicated by the enclosure for my TopLift. I’m pretty quick though, as I undo the center bolt on back and the 2 easy hand nuts (1 either side) closest to the tailgate. Then you can pivot the tailgate edge down towards floor - letting the axis that it pivots on be the 2 remaining hand nuts towards the seat. As long as you don’t have to remove the lid fully, its easy to reattach.
Broncolli
MD
'21 Back Diamond 4 door MIC
Does the tonneau cover still work, or is it higher than the sides of the truck ? I just ordered but want to be able to place the tonneau on top as well.
Aviator
Aviator
Detroit
youtube.com
2023 Bronco Raptor
I don’t have a tonneau, so not sure of how it attaches, but hope these images answer for you. Just took them.
Ford Bronco Ford's Cargo Area Enclosure with Fixed Lid - Installation Guide and Review IMG_1567
Ford Bronco Ford's Cargo Area Enclosure with Fixed Lid - Installation Guide and Review IMG_1566
Ford Bronco Ford's Cargo Area Enclosure with Fixed Lid - Installation Guide and Review IMG_1565
Broncolli
MD
Thank you !
Aviator
Aviator
Detroit
youtube.com
2023 Bronco Raptor
Thank you !
You bet. Let me know if you need any other images or info. I’ve had this for a week, and so glad I got it, even though it will slightly complicate my top removal/replacement with the TopLift Pro. It’s worth having a very solid and secure storage area. 👍🏻
Broncolli
MD
Is yours the more expensive one, the Deluxe ? That one looks like it is over the sides and you cannot use a tonneau - correct ?
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
I have a 2-dr, but keep my back seats folded down. It seems (from Ford's pics) the 2-dr cargo enclosure would be too short to cover the entire cargo area, as they show it with back seats up.
I wonder if a 4 door cargo enclosure would fit?
Aviator
Aviator
Detroit
youtube.com
2023 Bronco Raptor
I think it wouldn’t work correctly, because the side plates/walls are cut precisely to meet the rise of the seats hinge line that cuts across the cargo floor. I don’t think the greater length of the 4 door sidewall hardware would fit over the shorter distance to the seat fold point on the 2-door.
Ford Bronco Ford's Cargo Area Enclosure with Fixed Lid - Installation Guide and Review IMG_9531
broadicustomworks
I’m not sure, bought it second-hand.
It looks to be the factory-offered one from the get-go as far as I can tell, and as far as I know.
mid the deluxe one is one with a lid with gas struts, yes.
FWIW I see no room or really a need for a tonneau with it. Kinda serves that purpose as well.
