Fox 2.5 Install Help
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
Still working on the specifics, but we will be offering a different piston and spring upgrade for the rear Fox shocks. Spring rate is too soft in our opinion and valving needed some help.
given that there are so many different spring part numbers for the various trims and option packages, I wonder if Fox based their rates on a lower rate spring? I imagine since you say the springs are too soft and valving needs help, you also think they need stiffer damping as well?
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
Hard to say what model they tuned for. Piston/valving needs to match the spring rate so we change both at the same time.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I ordered the Fox suspension over 2 years ago. I finally went with something else and cancelled my order because they were taking so long to deliver. With all that time you would think Fox would have the spring rate and mounting issues correct for the Bronco.
AccuTune Offroad
Totally agree and don't blame you. What did you end up going with?
rguest3
Raymond
O-BRONCO-O
Jordan
Southern CA
Installed the Fox 2.5’s yesterday. Gave it about 1” front and back without making any adjustments from the factory preload. Didn’t drive it much yet. At the shop for an alignment this morning.
Ford Bronco Fox 2.5 Install Help IMG_3234
Ford Bronco Fox 2.5 Install Help IMG_3241
Ford Bronco Fox 2.5 Install Help IMG_3242
TieRod
AZ
2023 Bronco
I have the RPG kit with Fox 2.5's being delivered next week, after many months of waiting. How is the ride quality?
O-BRONCO-O
Jordan
Southern CA
Ride quality is great. Definitely a “softer” feel than the stock shocks. I have them set a 3 clicks from counterclockwise (softest). Going to play with the settings over the next few weeks to see what feels best for the road.
TieRod
AZ
2023 Bronco
I see your running 37's. Any rubbing issues? Looks great BTW.
O-BRONCO-O
Jordan
Southern CA
TY!
No rubbing so far. The front crash bars are pretty close when I flexed the front end. Might do the JKS crash bar removal just to be safe.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Are these tuned or off the shelf? Were you able to get the ride dialed in? How’s it handle on/off road. I’m debating whether to get them off the shelf with 250 lbs rear spring or jump in head first with a tuned setup from Accutune.
O-BRONCO-O
Jordan
Southern CA
Mine are off the shelf purchased through Camburg. I installed them models without adjusting any of the preload.
I set the compression adjustments at “5 clicks from softest” for both high and low speed. They ride great but the rear does feel a bit soft. I haven’t messed with adding some preload yet, which I would imagine should help some.
To be completely honest, I probably would have never thought the rear felt soft if it weren’t for everyone complaining about how soft it is. I really want to hear someone’s review after getting them tuned by Accutune. Probably something I’ll try down the road for sure.
t_laredo83
Tom
Golf Cart
Were you able to install the RPG UCA's with the 2.5 fox? Did the resi hose hit the billet arms or were you able to feed the hose through without any adjustments or rubbing?
TieRod
AZ
2023 Bronco
No rubbing on the hose and the billet arms look great, but its a real pain to adjust caster/camber after its installed.
Ford Bronco Fox 2.5 Install Help PXL_20230709_193453451
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Why are you using a chainfall?
