Front and rear bumper vertical alignment
NotApplicable
BEVs
For those in the know: how difficult is it to adjust the vertical placement of the bumpers on one or both sides?
I’ve noticed on my FE (and many other Broncos, particularly with the HD bumpers, via photos on this forum and Instagram) that one side of the bumper sits slightlyyyyyyyyyyyy higher than the other relative to the body. We’re talking .5-1cm difference between the 2.
Is this an easy adjustment to have made?
NotApplicable
BEVs
Ford Bronco Front and rear bumper vertical alignment IMG_0942
Here is my front bumper, for example. You can see that the right (driver's) side sits slightly lower than the left. Hoping it's an easy adjustment! My rear bumper has the same issue.
Like I said, I've noticed the same to varying degrees in MANY Instagram and forum owners' posts, particularly with the HD bumpers. Don't hold me responsible if you go inspect yours and find similar when maybe you hadn't noticed it before now ;)!
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '22 Escape Hybrid, 2 Harleys
Great! This friggin truck is going to drive my OCD absolutely CRAZY when I get it in the next year or three! 🤯
NotApplicable
BEVs
I suspect many wouldn't notice this. Although some look to be more noticeable than others based on my research.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
It's probably not your bumper. Particularly if it is the same in the rear. It's more likley that the body is sitting crooked on the body mounts to the frame. The body mounts are reasonably soft compared to the steel frame or bumper.
NotApplicable
BEVs
Is it really _more_ likely that the body is cockeyed relative to the frame than the bumper itself being misaligned/needing adjustment? I suppose there are probably locations (the body mounts themselves maybe?) that I could measure to determine if this is the case. If it is, is this normal/worrisome? I've never had, or at least noticed, a similar situation with my recent BoF vehicles...
It's hard to tell in this photo, but I've noticed that the bumper is similarly misaligned relative to the active shutters and the intercooler or radiator gills or whatever is right there near the ACC sensor, not sure if those would be expected to be aligned with the body or frame, but if what you said is true I guess they'd be in alignment with the body rather than the frame?
Raptor911
Raptor911
Broadlands, VA
Like every truck Ford builds, there are 2 frame horns (in cyber orange below) and your bumper is bolted to that frame horn. Just loosen the bolts on the driver side and raise your bumper to the desired height and tightened the bolts.
Ford Bronco Front and rear bumper vertical alignment 1627572953874
NotApplicable
BEVs
Like every truck Ford builds, there are 2 frame horns (in cyber orange below) and your bumper is bolted to that frame horn. Just lossen the bolts on the driver side and raise your bumper to the desired height and tightened the bolts.
You're magical! I will gladly find someone to pay to do this for me!
Tricky Dick
Dick
PNW
www.TD-Distributing.com
It could be both body and bumper. I once had an explorer that the body was set on the frame crooked and one rear wheel stuck out 5/8" farther than the other side, it wasn't apparent until I put bigger tires on.
Bumper mounts are almost always slotted for some fine tuning.
NotApplicable
BEVs
This is the stuff of nightmares for me
Tricky Dick
Dick
PNW
The thing is there's so much slop in the mounts you can correct it by loosening the mounts and shoving it over.
NotApplicable
BEVs
Did you stick a level on it?
This isn't an issue with it being level relative to the ground/gravity as suspension, the levelness of the ground, differences in weight on the left and right side of the vehicle confound that type of comparison.
