Good thing bronco will come with at least 35's.
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
As ranger needs 6" lift, ouch...............
BAUS67
redneck
Central PA
Ford Bronco Good thing bronco will come with at least 35's. 20200126_144248-
hey OX1 look at this pic and tell me if the control arm looks familiar?? 2-door bomber maybe???
BDS 6" Ford ranger with 35's
BAUS67
redneck
Central PA
Randy92Fox
Randy
Washington
66 Half Cab, 7.3 Powerstroke, 5.0 Convertible Fox
What size lift does a Ranger Raptor have over a regular Raptor?
Ranger Raptors ride on 285/70/r17 which is only 1.7" shorter than the 315/70/r17 spotted on the Bronco.
Edit: meant over regular Ranger not over regular Raptor
BAUS67
redneck
Central PA
I'm no Raptor expert (F-150 or Ranger) but I believe the use longer arms, which make for a wider track, but allow for longer travel.
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
Yeah, 33s rather than 35s, which is not a small difference in terms of fitting them into fenders. I can't find a hard number on how much it was lifted, but according to this article it has 2" more ground clearance, so probably around that much. It's also a differently shaped fender.
https://www.autocar.co.nz/car-revie...:text=Raptor uses the same 2.0,sec 80-120km/h.
Ford Bronco Good thing bronco will come with at least 35's. 1583641078427
Randy92Fox
Randy
Washington
https://www.autocar.co.nz/car-reviews-app/2018-ford-ranger-raptor-vs-ranger-wildtrak-comparison-review#:~:text=Raptor uses the same 2.0,sec 80-120km/h.
Ah, fenders probably makes quite a bit of difference in fitment in that case then
BAUS67
redneck
Central PA
Thanks Jalisurr. I knew someone would know more than I. Tire size has alittle to do with more ground clearance. i.e. no suspension change but put a taller tire on it now it have half of the tire increase more ground clearance. 2" taller tire = 1" more ground clearance.
BAUS67
redneck
Central PA
35's to start on the Bronco what happens when you put a 6" on that !!!!
( insert some kind of wow emoji here)
with the nice BIG ROUND wheel openings we have seen I'm banking on close to 40+ !!!!!!!!
(insert alot of wow emoji here)
OX1
jackson nj
Really depends on width at that point. Anyone running 40's on the F150 raptor?
(not really up on them)
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
you mean just like the original off road vehicle of North America? BTW, they would have scoffed at your puny 35" diameter axle raisers as well.
Haha, yes, exactly. Those things had great low range but TERRIBLE ride quality.
Just like a Wrangler!
