AKBronc49
Russ
Anchorage, Alaska
So my Limited F150 has factory power steps and over the last 10 years I have come to absolutely love them (and they still work great!) Plus my dad is disabled and my grandparents are in their 80s and they help tremendously for entry and exit. I'm not super tall or short person at 5'10" I did use my stock running boards but they were awkward.
Originally I planned to get AMP steps, I ordered a set through my wholesaler a year ago in March 22. They sat on back order until I finally canceled the order in July at the recommendation of my sales rep. My main complication was living in Alaska, so freight is a problem and I'm cheap and having access to wholesale pricing on vehicle accessories due to my line of work I just couldn't pay retail + freight.
I ordered the GoRhino boards on 3/8 and received them yesterday 3/14 I had plans that night so had to leave them until today. I started about 6pm and finished up around 10pm.
The instructions were pretty good. I had researched them as much as I could. I like the fact they have dual motors. They feel very well put together to me, I have experience with amp steps also and they are just as good fit and finish. I'm not sure how I feel about the magnetic sensors yet. Hardware is good, packaging was great.
These definitely aren't meant for heavy off road, if you high center on them you'll have rocker damage. This is not a concern for me as I use my Bronco more like a Mustang convertible that I can drive year round in Alaska. I will be adding longer front mud flaps to help keep rock chips down. Luckily I put mud flaps on day 2 and with the boards I had zero chips on the sides of my Bronco even after its second winter.
Here's some photos, don't forget dielectric grease on every connection!
Ford Bronco GoRhino E1 Electric Steps installed 20230314_134225
Thats just puddled water under the Bronco.
Ford Bronco GoRhino E1 Electric Steps installed 20230315_175756
goodbye fixed boards
Ford Bronco GoRhino E1 Electric Steps installed 20230315_182516
Ford Bronco GoRhino E1 Electric Steps installed 20230315_191517
Used vise grips with cardboard to hold pressure on the led lights
Ford Bronco GoRhino E1 Electric Steps installed 20230315_203959
I mounted the kill switch for the boards on the driver side b-pillar low so it's out of the way
Ford Bronco GoRhino E1 Electric Steps installed 20230316_215758
Tucked up
Ford Bronco GoRhino E1 Electric Steps installed 20230315_215709
Extended
Ford Bronco GoRhino E1 Electric Steps installed 20230315_215724
Ford Bronco GoRhino E1 Electric Steps installed 20230316_173749
*UPDATE* 3/28/23
After living with these I can't love them more, they work amazingly for my use and my family.
The only down side is without the step bar protecting the doors/rear flares everything flies up and hits the body. This is going to drive me crazy because I like to keep my Bronco clean. So tonight I installed some longer front flaps to try and cut down on rocks. I have some 3m PPF on order also.
Ford Bronco GoRhino E1 Electric Steps installed 20230328_202134
Ford Bronco GoRhino E1 Electric Steps installed 20230328_202112
Ford Bronco GoRhino E1 Electric Steps installed 20230328_202410
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Does this one come with a switch to raise/lower the steps when the doors are off? Similar to what the AMP has?
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
AKBronc49
AKBronc49
Russ
Anchorage, Alaska
You can Google the part number, I paid wholesale price through my work. I'm not sure what retail + shipping would be in the lower 48. Some places offer free shipping if you are in the 48 states. Obviously doesn't apply to AK and HI.
Yes, there is a small rocker switch. When placed in the "off" position they retract and will not move until they are switched "on" again. Also the lights are on a timer that shuts off within 5 mins if a door is left open.
AKBronc49
AKBronc49
Russ
Anchorage, Alaska
AKBronc49
AKBronc49
Russ
Anchorage, Alaska
Added some additional photos to the original post, location of the kill switch and picture outside with the boards in the up position. I'm really going to love these things. Best mod yet!
adamruiz2001
SoCal
Ford SVT Lightning
Searchdawg
Kentucky
2015 Supercrew Platinum 4x4
Those look great…in fact, they look identical to the Amp Research steps. I finally took delivery of my new Badsquatch on 3/8. The factory rock rails are nice, but my situation is similar to yours…I’m 5’9” and parents in 80’s, so needed steps. I have had the Amp steps on my 2015 F150 since new and they have always worked flawlessly. Amp steps are back ordered almost everywhere. I lucked out and found my local Line-X dealer had one set left in stock, so I had them installed. Anyone looking for a brand new set of take off factory rock rails that can pick up, give me a shout-$350.
Ford Bronco GoRhino E1 Electric Steps installed 00159955-69D8-452C-9268-D0B8F66B18B7
Ford Bronco GoRhino E1 Electric Steps installed 61772912-EBD3-4004-8D03-7E2465E3A730
OEM take off factory rock rails
Ford Bronco GoRhino E1 Electric Steps installed E8DC59DF-F90F-4F06-AA99-5821D511FB37
Gtrekker
Gary
Nice job....👍👍
Similar story with the Amp back ordered.
So, I installed the Rhino 2dr version and like them as well.
The wiring instructions were for the 4dr but was easily sorted out. I installed the magnetic switches to my front door, lower door jam and the switch near the driver's grab handle / vent area. Also, for 2dr install.... I would recommend installing the module prior to the rear driverside motor. Other than that, simple and good quality.
Dorf2point0
Richard
Anchorage, Alaska
2022 Explorer, 2005 Explorer, 2013 Escape
Yeah, that Alaska shipping thingy.. 🤣
SVTGoat
Maryland
So I was looking at going with a set of these but then I found the Rough Country which look identical for $1200.00.
Is there a reason you chose the Rhino over them? I haven't been able to make up my mind and I have even talked to both companies.
rblock50
Ryan
Orange County, California
VW, Bronco
I have been looking at the AMP, RC, and now these, thanks for the options. One question I had was how much lower and outward do these deploy vs. the OEM steps?
AKBronc49
AKBronc49
Russ
Anchorage, Alaska
A LOT the factory steps are borderline useless.
These stick out about 6-8" and split the difference almost in half from the door sill to the ground.
Compare these photos to the new steps above, the muf flap is a good indicator.
Ford Bronco GoRhino E1 Electric Steps installed 20230315_175108
Ford Bronco GoRhino E1 Electric Steps installed 20230315_175117
