Got my vin# but there’s a problem
Thomas1984
Thomas1984
Thomas
St.johns Newfoundland Canada
Dodge Viper
Optional wheels with the standard KO2s were added no problem to my order.
If you asked for the change after your VIN was assigned, you’re out of luck.
If you asked for the change before the VIN was assigned, you’re still out of luck but you should negotiate how the salesman will make it up to you for being uninformed and not configuring it the way you asked for.
Back in January I had the MT’s picked but a month ago I contacted my salesman to change to the A/T’s and now the options in the vin says A/T’s with the standard badlands wheels they must of selected it wrong on there end.
Thomas1984
Thomas1984
Thomas
Dodge Viper
Back in January I had the MT’s picked but a month ago I contacted my salesman to change to the A/T’s and now the options in the vin says A/T’s with the standard badlands wheels they must of selected it wrong on there end., are you saying I’m stuck with the standard wheels?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
If you have a VIN assigned, you are locked into whatever is on the submitted order.
If you do not have a VIN assigned, you can modify your order to your heart’s content.
Thomas1984
Thomas1984
Thomas
Dodge Viper
My salesman said on Monday when the boss comes back he’s going to fix it so I’m not sure
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Good luck!
I‘m not sure exactly how the WBDO system works in terms of the optional wheels, but we know what you’re asking for is 100% possible in the system.
There’s a few compounding factors, including the M/T tires forcing the Optional Wheels, but the optional wheels *not* forcing the M/T tires... as well as a few different optional wheels across all trims, so if they select the incorrect one it will give an error.
Finally, the way the WBDO works, because there are so many complex combinations, you have to build the vehicle from the ground up.... so in some instances you can’t just change one option without first removing all the subsequent options (even if they don’t seem like they should matter). If your dealer is insisting it’s not possible, it is... they just need to work out how to do it. If they can’t figure it out on their own, then they should call their Regional Rep for help.
*This is all assuming your VIN hasn’t been assigned / vehicle build hasn’t been scheduled.
Did you receive email notification that hour order is progressing? What does your Ford.com profile say?
Thomas1984
Thomas1984
Thomas
Dodge Viper
Good luck!
The salesman can’t see a build date yet, only certain people can at the dealership but it’s Saturday he won’t be able to do something about it until then, I never did get email build updates, only the updates from Ford
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Does your Ford.com profile still say “In-Store Order?”
If so, it‘s likely that they can still change things.
Ford Bronco Got my vin# but there’s a problem BE998BC8-E973-4309-B54C-A4EE99101327
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
I received my vin and I can’t get the ko2’s with the badlands optional wheels anyone else having this issue? I’m beyond mad
Order the vehicle. Work out the tires later. Maybe the dealer can swap them out for you upon delivery. Tires come and go quickly, considering all the other shenanigans going on don’t let tires become an obstacle. Good luck!
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I don’t disagree, but it sounds like the dealer added the optional tires to their order that they don’t, which is an extra $695 for something they don’t want to begin with.
@Thomas1984 Just to make sure I’ve got this correct:
You want the upgraded wheels, but with the standard BFGKO2 A/T tires and *not* the optional Goodyear M/T tires. Correct?
Ford Bronco Got my vin# but there’s a problem 1618682025375
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
ahh, I missed that part. Sounds fishy.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I just edited my post... because I want to make sure that the OP has which tire is optional and which is standard correct. There have been some people here already that thought the standard BFG KO2s were the optional ones on the BL.
Thomas1984
Thomas1984
Thomas
Dodge Viper
It’s the wrong wheels selected but the right tires that’s the problem
Thomas1984
Thomas1984
Thomas
Dodge Viper
You are correct
Thomas1984
Thomas1984
Thomas
Dodge Viper
Received.... and right now you just have the standard wheels and tires on the order. Cool.
Yeah, I think you have all the information you need. Good luck!
My vin and order number take a look vin# 1FMEE5DP7MLA67397 Order# 6412
