Hard top question... put front panels on without the main rear?
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
Im still waiting on my 2dr BD to ship and currently have a JKU Wrangler hardtop. I got rained on this weekend but I had the freedom panels (front panels) with me and was able to put them on to keep semi dry.
What I want to know is if the Bronco is capable of the same. Can you put just the front panels on without the main rear?
mpeugeot
You probably could, but it wouldn't be suitable for anything over 30 MPH or any serious wind. I could see them potentially drooping in the back potentially as well. This would be an excellent opportunity for a simple aftermarket bar to facilitate that possibility though. In which case, It would work.
ChrisB351
ChrisB351
Shreveport, LA
I was wondering since theres no cross bar on the cage like my Jeep has. The way its designed, theres a tab that flips down to support it on the frame and has 2 screw in pieces that come up thru it into the top panels.
Frappy608
NorCal
2022 Badlands Eruption Green
I'm currently in process having a bracket fabricated that would secure the back of the front panels OR the mid panel (I have a 4 door). Will post when it is finished.
JoshuaPrieto
Joshua
2021 Bronco, 2022 Explorer, 2022 F-150
While you could latch in the front, you cannot latch the back - very unsafe.
ChrisB351
ChrisB351
Shreveport, LA
Thats what I was wanting to know is there was a way to secure them since theres no rear mounting point.
1979
Baltimore, MD
There’s a few accounts on Instagram saying they’ve run with the front panels only installed at highway speeds with no issues.
At least 1 also claims to be developing a crossbar to secure the panels.
zio
NorCal
Cars
The panels installed without rear clamshell are solid. The middle section clamps down on the sides and the fronts add stability.
ChrisB351
ChrisB351
Shreveport, LA
I have a 2dr coming so no mid panel
Mrjohndon
Houston,tx
2022 bronco
did you get this made?
ChrisB351
ChrisB351
Shreveport, LA
Since this post was revived Ive had my Bronco 10mo and over 15k miles. Ran it many times with just the front panels with no issues.
Mrjohndon
Houston,tx
2022 bronco
I think the front is easy, even at high speeds. curious about the mid section though. like idea of a bracket, but not sure how.
81arctic
Jon
Granville MA
2021 MT 2.3 Badlands
I actually do this semi-regularly with no issue whatsoever. I leave the bolt on rear section in the garage from may-october and keep the 3 front panels with me in the bag jut incase I run into some rain. The flip latches in the front, 2 twist latches in the middle and a twist latch on the side/rear of each is PLENTy to keep them from flying off, and they are way too rigid to "droop" but I did start carrying a 12" section of pvc pipe that is the right diameter for the rear swivel latches to grab onto sometime last summer. Its just a little bit of added rigidity which keeps them from rattling while off road or and holds a good seal for more conventional driving. Pretty simple "mod" and really no issues at all on my second summer doing that with 30k total miles on the truck.
rblock50
Ryan
Orange County, California
VW, Bronco
I had all of my panels off, but it got sunny so I put just the front ones on without the mid or rear, and it worked just fine at all speeds. I didn't try the middle section, but I've seen other posts in here with folks doing it. They didn't seem to have problems. Would be good to be able to secure it to the "rollbar" just in case.
