Hard top removal & hoist questions
Klink
Pennsylvania
2013 f-150 FX4
I'm going to be mounting a pittsburgh electric hoist from harbor freight under my carport. This should enable me to remove/install back shell by myself. I have few questions.
1) can you leave the factory roof rails attached (rear mounts of course) and use them to hook onto?
2) where is a good place to strap onto otherwise?
3) how many straps should I use? Was thinking 3 minimum to keep it level while lifting.(2 towards rear where all the glass is and1 dead center on the front.)
I'm really a newbie here and don't want to drop, twist or otherwise damage this mic top.
Sidenote: my wife helped me take it off last night and it was sketchy with her. She said never again.
Forgive me if this was covered. I couldn't find anything relevant in the search.
MayhemMike
Mercury
I used the same electric hoist. Two ten foot by two inch wide nylon straps. One two foot strap to connect all the ends of the ten foot straps. The two bungee cords keep the top from free spinning in the breeze. Takes a time or two to find a balance point. This is the top from a two door. Laying the straps flat allow the rear window to close.
Ford Bronco Hard top removal & hoist questions 87DFE248-A83B-4491-AFEF-54E5E78F47F8
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Topsy has free plans for a unistrut lift frame if you want to get crafty with it. Sized for the Jeep hardtop so you'd have to shorten it a bit, but I'd imagine it would work great for this application:
https://topsyproducts.com/collections/hoist-systems/products/diy
I'm (probably needlessly) concerned about introducing compressive loads into the hardtop and I don't have a ton of overhead room, so this kills two birds with one stone and will probably be my project next month.
Klink
Klink
Pennsylvania
2013 f-150 FX4
@MayhemMike how did you attach the straps to the top? Can't tell from the pic. Are they completely wrapped around underneath of it?
thatspecialbeat
Ryan
Meridian ID
Subies
I was a bit worried about that. I am actually going to do a lift install this weekend and probably will just run the strap without a frame.
But I am going to set it down on a cart and not keep it stored on the lift.
MayhemMike
Mercury
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
2 inch x 12 foot straps
one 3/4 inch shackle
Ford Bronco Hard top removal & hoist questions CCCAE2B7-2F43-4555-913D-2B49CCDA4B6D
Ford Bronco Hard top removal & hoist questions 20E538AA-8A00-4410-8292-59AA13C53E75
Ford Bronco Hard top removal & hoist questions 19F0F33D-C9CF-4A5E-BAA9-3DC4D9624E23
Klink
Klink
Pennsylvania
2013 f-150 FX4
I see. It will fit between the back glass and the top. I was thinking the other way and it would squeeze the sides in. You guys were a great help. Thanks!
