Hardtop to soft top bracket.
pimpjuice
ocala, fl
bronco
I have a hardtop build but bought a factory soft top. Upon installation, I noticed two things missing
1. The bracket that connects the 3 bolts of the soft top to the frame
2. The plastic cover for said bolts
Does anyone have these for sale or know the parts number?
Bronco1833
Chad
Wilmington, NC
Ford Bronco
Following… find out anything? I did the same. Tried to install a factory soft top on my FE and didn’t have area for the main bolts.
pimpjuice
ocala, fl
bronco
Nothing yet. Dealership is still trying to find the parts number. I'll let you know if I find out anything
BroncoDymond88
New Jersey
'23 Bronco
Wow it is your lucky day!
Just went through this myself and spent tons of time looking over the spec sheets with my dealer. The black brackets that the soft top bolt onto are M2DZ-7829452-A .
The trim covers are:
Right Side: M2DZ-7831288-BA
Left Side: M2DZ-7831289-BA
Also, if you need bolts for the soft top & bracket: W707288-S442
Did yours have the brackets above the read seats? Mine didn't. The only parts I'm missing at this point are the plastic trim on both sides that the windows clip into. They've been on backorder for weeks.
pimpjuice
ocala, fl
bronco
I can't thank you enough for this! I'm sure others will find this information helpful as well!
OBX2021
New York
2021 Bronco 4dr Outer Banks
This is incredibly helpful as I am trying to do the same conversion. My dealer told me it would be "thousands" in additional parts 😂. It looks like it's 4 parts total and under $500 (not including the top) if I am reading it correctly? How many bolts are needed?
pimpjuice
ocala, fl
bronco
The brackets and covers came to like $170 without the bolts (I had extra).
You need a total of 10 bolts for the back and 4 for the center latch bracket (on top of the pillars).
2 bolts on each side of the bronco will hold the rear bracket to the frame, then 3 bolts will go on the other side (2 to the bracket and one directly to the frame).
All can be the same ones you used for the hard top. I forget how many (4 or 5 total) will need a washer.
Sorry I should have taken pictures during the process
pimpjuice
ocala, fl
bronco
The parts department at Gary Yeomans Ford Villages is AMAZING! When he couldn't find the part number, he browsed this site, found the part and ordered it for me. I went in to show him someone replied with the part number and he already had the parts waiting for me!
Top notch service! I highly recommend giving them a call
OBX2021
New York
I called Gary Yeomans Ford, thank you! I was told you (or someone else they had done this for) actually had a soft top from an existing bronco? This is important because Ford doesn't sell the complete soft top, you have to order it in parts. See picture that my dealer sent me. I guess I am going to need to try and buy and existing soft top from a Bronco owner??
Ford Bronco Hardtop to soft top bracket. Captur
pimpjuice
ocala, fl
bronco
Yeah I was able to find a guy on this site that sold me the soft top. There's a few people that had a factory soft top and bought a best top.
Search the market place on here and you may be able to find one in your area.
Make sure they include the latches in the rear and middle, and the bracket.
StyleGuy
OK
Bronco FE, Jaguar F-Pace, GMC Denali XL
Great info! Thanks!
Are the brackets the same for both driver and passenger sides? Same part number?
I may see if I can just trim my hardtop trim covers before I buy the soft top version.
BroncoDymond88
New Jersey
'23 Bronco
Great info! Thanks!
The brackets on top are the same, they are labeled as L/H,R/H
RogueSqdn
Advance, NC
2024 Bronco HLE
Is there a full list of part numbers for everything you’d need, including the top? I want a factory soft top for my FE, just don’t really want to order a used one if I can avoid it.
pimpjuice
ocala, fl
bronco
Used are typically rarely used because people remove them immediately. The price plus shipping maybe up there for new.
  • Like
Reactions: BMP
RogueSqdn
Advance, NC
2024 Bronco HLE
Oh, I realize most are used for now. My concern would be mainly whether I’d get all the parts necessary to attach it, and of course that the top would be in good condition.
