Has anyone upgraded their alternator to run a second battery?
Pierretx
Pierre
23 Bronco Raptor, 23 Raptor R
Has anyone ran a dual battery system, using the oem or upgraded alternator ? I know there are other options like self contained batteries etc but I'm very set on building this aux bat system with the/an alternator being the only charging source for it. Thanks in advance!
JohnnyBronco
Pennsylania
X4
With the standard alternator output you should have no problem keep two batteries wired in parallel fully charged. Last vehicle I had with twin batteries was my 78 Chevy diesel pickup. Downfall with it was undersized cable running from battery to battery.
JohnnyBronco
Pennsylania
X4
BTW many vehicles put the main or only battery in the trunk.
da_jokker
Jeep Wrangler JKUR
Yeah the issue isn't the generator, it's finding a place to put the second battery.
tfrazier
Tony
South Carolina
23 Bronco BL 2.7, Lincoln MKZ, Newell Coach (RV)
The other potential issue you might have is with the IBS (intelligent battery sensor), which monitors your batteries state of charge, health and function. Not sure if adding a second battery will impact this. Just putting it out there.
Bellime
Keith
2022 Ford Bronco
Just wish there was a better place for the second anchor.
BroncoAZ
Mitch
21 2 Door Badlands 6MT, 01 Expedition, 24 Tesla Y
The IBS sensor can be overcome by connecting the wires to the truck side of the sensor. The on demand charging poses a bigger problem, the alternator is variable output and doesn’t account for a the second battery. The solution is a DC to DC charger for the second battery. I picked up a 20 amp Renogy charger on prime day for $91. I think the 20 amp will be fine as I only plan on running the ARB fridge off a small second battery. The larger 40 amp and 60 amp chargers require a dedicated 4 gauge wire if mounted in the back. I’m planning on a single 4 gauge wire for the charger and stereo amps. I’m not sure what or where I’ll be doing with the spare battery(ies).
Ford Bronco Has anyone upgraded their alternator to run a second battery? IMG_5932
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
Is it H2O proof down there?
Like...cr117 posted:
American Adventure Labs has a kit for the rear cargo storage area.
Their system has worked great for me well over 15 months now. Check out their website.
Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
I have found a company that will make ups a 370amp alternator for the 2.7 engines in our bronco. But they need about a 100 orders to make it worth their while to design one. The cost would be about $500 each. With a 5 year warranty. Less if you will give the. Your old used alternator from your bronco.
think we can find a hundred?
B22-2023
Houston
I'd buy one. Maybe start you could start a survey thread and get a bunch of people to sign up.
CBass
C
Pflugerville, Texas
2024 Ford Bronco/2024 Toyota Sequoia Platinum
Genesis makes a dual battery setup, I installed one in my Raptor. Here is the link to the thread I started, I did have some minor issues which have all been worked out.
https://www.bronco6g.com/forum/threads/genesis-dual-battery-kit.100509/
Been running it for a couple of months now with zero problems. Here are a couple pictures of it in my Raptor. There is a ton of info on why you don’t need to upgrade the alternator on the Bronco, just search the forums or Genesis has a video talking about it. Hope this helps!
Ford Bronco Has anyone upgraded their alternator to run a second battery? IMG_1975
Ford Bronco Has anyone upgraded their alternator to run a second battery? IMG_1980
Ford Bronco Has anyone upgraded their alternator to run a second battery? IMG_1992
