Help! Caught Between a Cactus and a Hard Place!
FourHorses
Currently own 6 Fords
Looks exactly like this picture depicts.
Ford Bronco Help! Caught Between a Cactus and a Hard Place! 3
DannyG
Daniel
New Mexico
2010 LR4, 1995 Ford Bronco
I've gone by the dealer to see Cactus Gray four times (Rangers and Bronco Sports). It looks different in the sun vs a cloudy day, but I liked it. Should look good with darker MIC top, until I get a white top. ;)
Philly
Dallas, TX
2022 JL Rubicon
Take a look here and here. It's a cloudy day in the first one, but the color is accurate. In the second, it is under artificial lighting, but I would say it is also accurate. It all depends on lighting conditions and the environment. Your perception of color is also a factor. Many never see the green tint, but I have found most do. I almost always see the green, but it does disappear given the right angle and lighting.
The best thing you can do is go see it at a dealer multiple times in different lighting conditions. I originally ordered Oxford White, but made the switch to Cactus Gray after seeing it on the two-door Bronco in person. The color looks great on the full size Bronco.
Ford Bronco Help! Caught Between a Cactus and a Hard Place! 1614812562310
Ford Bronco Help! Caught Between a Cactus and a Hard Place! 1614812591961
Big Boss
Outer Heaven
Bronco Big Bend
OP you need to go to a dealer and see it in person. It's a color that photographs terribly. It truly needs to be physically seen with your own eyes
