Help deciding between the Wildtrak and Badlands
midwestpilot
Kansas
Equator
Alright so non-negotiables are the Lux package, the upgraded shocks in some form, and v6 plus front/rear lockers. The outer banks is out cause the interior looks terrible with race red and I can stomach the cloth colors on wildtrak. I can kinda take it or leave it on the washout floors and MGV, although I see the advantages.
Use case-this will be an overland vehicle although I would like to take it on difficult trails as well. This will be my entry point into this sort of thing and I do plan on taking off-road courses. I’ll have a two week on two week off schedule so this thing will be used frequently and I plan on exploring all corners of the US with it. This is not going to be a rock crawler but I’d like it to be fairly capable.
My personal baseline for buying things is to over buy my use case. I’ve been caught off guard too many times and the price difference between a base outer banks with Lux and a wildtrak/badlands isn’t too bad. My only problem is for those with experience, how limited am I going to be with no sway bar disconnect? Like is this thing gonna cripple me on some trails or with proper prep I’ll be fine in 99.999% of use cases? A wildtrak with options is exactly the same price as a non squatched badlands with everything I want. I kinda of like the idea of having the squatch with extra clearance but if it’s really not necessary then cool I like the interior on the badlands better. If it’s better to go with cloth comfort wise vs MGV I’d go with wildtrak. If I got the wildtrak I’d probably swap tires to all terrains right away too. Help me decide!
Wildtrak build:
Race red
MIC top
Modular bumper, full steel bash plates.
Towing package
Lux package
Tube steps
Sandstone cloth
~57k
Badlands build:
Race red
MIC top
Beadlock wheels 33” tire
V6
LUX
Towing package
~57k
mpeugeot
You can always put some custom fitted cloth seat covers over the MGV and have the best of both worlds. I really wish I had thought of that earlier, because I might have spent the extra few grand to get the Badlands. Instead, I went with the roast cloth in the OBX with CG paint (which honestly looks amazing). Anyway, neoprene seat covers are also available for cloth seats and would provide a level of water resistance which would exceed what the cloth offers. As for the Sway Bar Disconnect (SBD) - you can add a manual SBD later, it's less slick, but effective.
I gave up the 35" tires, sway bar disconnect, and front locker... but I did save money on the build ($48765 MSRP) and I used the extra money to purchase a set of off-road rims and tires. Which gives me a nice highway setup and a weekend set of off-road shoes. The RTR Tech 6 wheels (17x9 +30) and 33.5" Milestar Patagonia M/T (295/70R17) tires ran a total of $1740. These should fit the OBX with ease.
Given your use case, you could pick either and it wouldn't be a mistake. My gut says to go with the Badlands, but I can see the case for the WildTrak.
Drex
Jake
Both will work fine for your stated use and wants. You might need to budget for different tires on the Wildtrak if frozen precipitation is on the menu. The pricing is going to be similar, pick an interior you like best, or hate least, and don't look back.
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
Badlands - because sure sway-disco is cool for the videos where you see the wheel drop, BUT it's going to make beaches, fire service roads, washboards all the more comfortable below 20 (25?) MPH.
midwestpilot
midwestpilot
Kansas
Equator
I totally forgot to mention that but I will be in an area that has snow frequently so I do need tires that will perform. So wildtrak will not have the mud tires on it for long
Mirunner
2022 or 2023 Bronco
I was torn between the 2 as well and still am torn a little because of price just like you. I would still go badlands without sasquatch in your case. Badlands is the ultimate off roader as it is fully equipped to go off road. The electronic sway bar disconnect is a must have if you are planning on going off road. Wildtrak is great for off road and would be great for silver dunes here in Michigan. However, with the trails here in Michigan (just had my wifes Jeep up north on Memorial day on tin cup) I would recommend the badlands for our trails versus dessert running trails. I see you are a fellow Michigander. The Wildtrak would probably be ok for everything I am planning on doing, but I would rather have the sway bar, wash out interior, and mgv seats for off roading I am planning on doing while I own this vehicle for years.
Tdifonzo
Thomas
Audi S3
Sounds like it comes down to MGV seats vs. Sport mode. I would probably go Badlands for the seats unless you really want 35" tires.
midwestpilot
midwestpilot
Kansas
Equator
If the 33s are good enough clearance for most situations I’m good with it. I just always want the best haha.
BroncoT
SUV
I’d go Badlands, though I’m going to face this same decision when the 2022 B&P is released. Not that I expect much change to either model, but more because I’ll need to resubmit my order anyway.
if I decide that I gotta have 35s, well, not sure what I’ll do.
midwestpilot
midwestpilot
Kansas
Equator
I figure by the time I need to change the tires the secondary market will have some good options for a slight lift to get those 35s on there. I’m hearing though with the flex the 33s have that it’s gonna be pretty amazing since the 35s have a bump stop.
Espy
2023 Ranger XLT Tremor
I was focused on OBX until I figured out I was trying to build a BL (swapping body color flares for BL flares, adding 17 inch wheels and 33 inch tires). Looking at the price of BL I was getting into WT money so went to WT. I'm now set on BL. SAS is overkill for my use case so I'm back at BL and limiting my options to keep it at $50K-ish based on my dealer's pricing.
EDIT - I think BL is the choice.
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
Both are great options and you can’t go wrong. So, seems like you just have to decide 35s vs 33, 4.7 gears vs 4.46, cloth vs MGV and manual disconnect vs push button disconnect.
On a side note, if you do plan to off road, you may want to consider removing the tube steps and adding rock rails (if you go WT) as the tube steps will get beat up if you do anything more than moderate off-roading.
