Help needed with wiring an ARB button to the twin compressor
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
A tip for grapping powe from the fuse block instead of a fuse tap. ford gave us locations to pull ignition power and constant with an additional pin out in the fuse block. you can order PN DU2Z-14474-DA for the pin.
I would use the run/start spot
Ford Bronco Help needed with wiring an ARB button to the twin compressor 1668544072021
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Ford Bronco Badlands
Thanks, what is the benefit of doing that? Like more official way or tapping a fuse is not a great way to do it in general?
Mikerider
Washington
Just a cleaner way to do it and utilizes what the factory designed for accessories.
I am always looking for ways to make my wiring better.
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
I need some advice. I wired everything and everything was fine for a few days but today I figured out I can turn on the button any time even if the ignition is off. So I checked the port and it's under power all the time. I moved the fuse tap to a different port and everything is fine, but the USB port is now under power all the time. What should I do? What did I do wrong?
Karl_in_Chicago
Karl
Chicago
Is it possible the circuit you are on is one of the ones that has the time-out so that it may initially appear it's always-on power but after some period of time (I forget how much, it's been discussed elsewhere) the power is cut off?
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Yes, you are right. But I am not sure. OR the timer is really big, like 30 min or more (I am still trying to figure it out) OR something resets it (like opening a door, or something else) OR I did something wrong. Anyway probably I should move it to other spot.
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Thanks a lot everyone for help. Here is the result :) Probably I will move the tap to the 360 camera slot.
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1621
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1622
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1623
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1624
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1625
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1626
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_1628
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
Not sure why, but today everything acts as expected. No delays. Yesterday probably was a bad day. I will keep an eye on it and see.
evgenyvasenev
evgenyvasenev
Evgeny
Gig Harbor, WA
vasenev.com
It's happening again :D Not sure what is going on, will try to find any logic :)
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
So glad to find this thread. Yesterday I mounted my compressor under the hood and then I looked at the wiring, gave up, went inside, and had a drink. :ROFLMAO:
I think I'll be able to get it sorted now.
I do have a question though. I noticed the OP mounted his compressor with the wiring of the compressor on the driver side and another poster here had a pic of his compressor with the wiring on the passenger side. Completely a matter of preference? Or should it be done one way and not the other?
mikec426
Russellville, AR
Finally had a chance to do this today. Got it all wired up… and nothing. :(
I’m inside cooling off and reading and trying to figure what I did wrong.
mikec426
Russellville, AR
Ok, nearly started an electrical fire under the hood. Time to quit… (glad I noticed the little wisps of smoke!)
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_8033
Arokcrwlr
Kraig
US - Alabama
There is a purple wire and a black wire in that loom that goes to the isolation switch. If I remember correctly, that's all you need. The rest of that harness that is connected to that is unused unless you're installing a manifold and/or ARB lockers..Give me time to get home and I'll take a look.
Arokcrwlr
Kraig
US - Alabama
So I went back in this thread and realized I didn't tell you anything new above. So, my question is how do you have it currently wired? Maybe if you explained your setup someone can help. I recall the wiring being very simple, so hopefully an easy fix.
mikec426
Russellville, AR
Ford Bronco Help needed with wiring an ARB button to the twin compressor IMG_8044
No worries.
I did the 3 wire setup to the switch just like in one of the videos posted earlier on this thread. Here’s a sketch.
