- Thread starter
- #1
I bought a DV8 bumper and the Elite 13" light bar to go with it.
https://dv8offroad.com/collections/...oducts/6th-gen-bronco-factory-bumper-bull-bar
https://dv8offroad.com/products/13-inch-led-light-bar-be13ew45w?_pos=1&_sid=13ef6c078&_ss=r
There are zero instructions on how to hook it up. It is not overly hard using their on/off switch. I have it all hooked up and working fine using their on/off switch. I want to use my AUX though. Looking at the wires going to their switch, there are three wires. I tried to slide in the purple AUX wire that is located in front into each of the three pins to see if I could get lucky and it would come on, it did not. It does not come with an easy connector like the Morimoto harness does where you unplug their on/off and attach the one for AUX. Im sure it is an easy fix, just dunno what to do.
How do I change the switch to my AUX? Below are the pics of their three wire hookup, and showing that it works. Does the purple just not have enough juice to run the light?
