How can you tell if a crack or chip in a windshield needs repair or replacement?
Hooke Road®
Lux Sponsor (Level 2)
Hooke Road
CA
www.hookeroad.com
The decision to repair or replace a crack or chip in a windshield depends on several factors:
  • Size: If the crack or chip is larger than a quarter, it will likely need to be replaced. Chips smaller than that can often be repaired.
  • Location: If the crack or chip is located in the driver's line of sight, it will typically need to be replaced. A chip or crack located in the outer edges of the windshield may be repairable.
  • Spread: If the crack or chip has started to spread, it will likely need to be replaced.
  • Age: Over time, a crack or chip can spread and become larger. If it has been some time since the crack or chip first appeared, it may need to be replaced even if it is still small.
It's always best to have a professional assess the crack or chip to determine whether it can be repaired or if it needs to be replaced. Driving with a cracked or chipped windshield can be dangerous as it can obstruct the driver's view and make the windshield more prone to shattering in the event of an accident.
If you have other better judgment methods, please comment and discuss!
JohnnyBronco
Pennsylania
X4
If within the sweep of the wipers some state inspections will require replacement not repair
CoryB20
Bronco Sport, F-150, Wrangler
What is a “toonie” mentioned In the size of rock chip?
Lxatoledo
E
Albuquerque
75 EB Ranger
I have about 250.00 worth of resin on my windshield and run with an extra repair kit. Rock magnet!
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
A Toonie is a $2 Canadian Coin. We also have the Loonie, a $1 Coin with a Loon embossed on it.
Consider a Toonie to be equal to 1” in diameter (it’s a tad larger, but you get the idea)
CoryB20
Thanks! I figured it was some form of Canadian currency but had no idea of the size.
