How do you plan to wash your undercarriage?
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
Ordered.
In the past I've used one of those cheap rainbow-pattern lawn sprinklers, moved it as needed after a while. Very passive, weak stream, takes a while.
This is much better.
Thanks for the link!
Same here! it gets the big clumps of TN mud off, but this pressure will make it quicker and more effective.
broadicustomworks
Hanging Rock, North Carolina
As a follow-up:
I bought this and used it, and it does very well.
You still have to use the nozzle/hose to get into the crevices and between stuff (and on top of stuff like skid plates, transfer cases, crossmembers).
But overall a great value for the benefit.
Highly recommend.
NotApplicable
BEVs
Touchiness car wash. No issue with tire width or clearance, and has undercarriage wash.
bravely
Brad
3490 s leonard rd, new palestine in 46163
1973 Mustang
I was totally on board with running my Bronco through the auto car wash down the street until I decided to upgrade to Sasquatch package. The tires are too wide to fit through the wash, and probably hits the height restriction.
I did some research and came across this Ryobi undercarriage pressure washer attachment (Ryobi Pressure Washer Water Broom). It seems like a good solution. The only problem for me is that I store my hoses in the garage for the winter so I'll have to think that one through some more.
  • For those of you who are going to have Bronco's that you wouldn't dare take to the automatic car wash, what's your plan for keeping your vehicle clean?
  • If you live in an area where snow/ice on the roads is common - what's your plan to keep the salt off the undercarriage?
if you're real muddy, some car washes won't let you through. my jeep buddies spray the under carriage with wd40 before muddin
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Ryobi released a version. Seems pretty nice. I have yet to try it. Probably one day this week.
cclkramer
Coeur D Alene Idaho
2000 ford f350 diesel dually
I run mine thru the brushless carwash with the under carriage cleaner
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
We have the ryobi one at work. Works great
badclam
Jefe
PNW
23 Braptor,22 Raptor 37pp,23 F350 CCLB 6.7PS
