- Bryan
- Aug 5, 2021
- 35
- 3,790
- 9,630
- New England
- Ford Bronco, Escape, Focus
- Badlands
If you watched my last video you will know that I installed the B&O subwoofer. This time I have upgraded that B&O subwoofer with a Kicker 8" sub!
Check below the video for a TON more information that I've collected.
Other videos/guides I've created on the topic of audio upgrades:
AUDIO SYSTEM VARIANTS
As of now (mid-2023) there are four variants of audio systems in the Bronco. How you add/upgrade your subwoofer will depend on which setup you have.
2021 - 2022MY Six-Speaker
This was the audio system that was included in all non-Lux packaged Broncos. There is NO factory subwoofer, nor is any wiring available to support a subwoofer.
2023MY Seven-Speaker
Included in early 2023MY Broncos. This is identical to the 2021 - 2022MY setup, with the addition of an 110 watt amplifier and a 170mm (~6.75-inch) subwoofer.
2023MY Seven-Speaker with Sub Delete
Ford messed up and ran out of subwoofer components. Functionally the same as the 2021 - 2022MY setup. HOWEVER, it contains the wiring and the 170mm enclosure necessary to hook up a subwoofer & amplifier.
2021 - 2023 B&O
This is the premium audio system included with the Lux package. There are 7 speakers with a single subwoofer measuring 200mm (roughly 8") in size.
PICKING YOUR SUBWOOFER
At a high level... there are three decisions you need to make when picking a subwoofer:
Voice Coil Impedance
You will find that subwoofers intended for car audio generally come in two impedance ratings: 2Ω and 4Ω. There is a lot of electrical and power engineering I could dig into, but just to generalize it:
2Ω voice coils will be much louder and more more "boomy", as they can handle more power flowing through the voice coils. Those who dislike 2Ω voice coils often describe it as sounding very "sloppy", while those that like it often describe the bass as very "full" sounding. If you are driving those 2Ω voice coils with an underpowered amplifier, you run the risk of overheating your amplifier and/or creating very "muddy" sounding bass.
4Ω voice coils will have a more tight and clean sound. Uses less power than 2Ω voice coils, and generally more "safer" for underpowered amplifiers. For this reason... if you are running a factory amplifier rather than aftermarket, I generally recommend sticking with 4Ω voice coils. Those who like the sound of a 4Ω subwoofer would describe it as "accurate" sounding, while someone who dislikes 4Ω voice coils will often say it sounds "constrained".
Speaker Diameter
Generally speaking, the bigger the subwoofer the better. BUT, the bigger the subwoofer the more power and space it will require. Unless you are willing to devote your entire cargo space to a subwoofer, most of us will have to come up with some sort of compromise when it comes to the size of the subwoofer.
If you are mounting your subwoofer in the factory location—in the cargo area passenger side panel—you have two sizes available: 6.75" and 8" subwoofer speakers. BUT, there is aftermarket enclosures available—more on this in the enclosure section.
Obviously your subwoofer will need to be able to physically mount inside of whatever enclosure you select. This will be highly dependent on which enclosure and subwoofer you select, and there is a near-infinite amount of combinations available. The only real advice I can give here is "RTFM and measure before buying".
RMS Power Requirements
Obviously you need to pick an amplifier that is capable of powering your subwoofer. More on that in the next section...
PICKING YOUR AMPLIFIER
There is a TON of amplifiers out there in the marketplace. I definitely encourage you to shop around, and gather suggestions from the forum.
One of the more popular amplifiers is the Kicker Key 500.1, which is the amplifier I personally selected—largely because it was compatible with the Plug-n-Play Kit I bought. My brother—who generally knows more than me about car audio—also suggested the Kicker CX series of amplifiers. In my past I would have highly suggested AudioControl amplifiers, but admittedly I have zero experience with their current product offerings.
Arguably the most important part of any subwoofer amplifier is the amount of power it can deliver at a given impedance rating. It's probably easiest to explain this using an example...
Pretend I have selected the following components:
The subwoofer has the following specifications. Notice the recommended amplifier power is 300 watts. This is the recommended power output when the subwoofer's voice coils is wired in parallel.
What does this parallel business mean?? Well... there is two ways to wire a dual voice coil subwoofer. If you wire subwoofer in parallel, the impedance rating seen by the amplifier is HALF of the value of the voice coil rating. If you wire the amplifier in series, the impedance is DOUBLE the value of the voice coil rating. A 2Ω subwoofer in parallel will cause the amplifier to see 1Ω of impedance. If that same subwoofer is wired in series, the amplifier will see 4Ω of impedance. Wiring diagrams below:
In this case, our subwoofer has 4Ω voice coils, and when wired in parallel, the impedance seen by the amplifier is 2Ω. The Kicker Key 500.1 is rated for 300 watts and 2Ω impedance, which matches the subwoofer's requirements. So we're good to go.
Modern amplifiers are also typically packed with a ton of added features that you may or may not find helpful. Definitely read user manuals, check out reviews online, etc. etc.
SUBWOOFER ENCLOSURE
General speaking there are three choices for subwoofer enclosures:
Whichever you decide... check your measurements.
HOW TO WIRE YOUR SUBWOOFER AMPLIFIER
Obviously this will vary widely depending on exactly what gear you purchase. So I am going to speak in extreme generalities. If you need help filling in the gaps, let me know.
POWER
Most people will have to pull their amplifier power from the battery, but the 2023 have the option to pull their power from the factory wiring, assuming they have a relatively low-powered amplifier.
GROUND
Just about everyone will be able to use the ground near the passenger rear cargo area behind the panel. Those with the 2023MY may also use the factory wiring provided, but keep in mind the ground wire should be the same gauge as the power wire or larger (thicker cable).
AUDIO SIGNAL
This is where it gets interesting...
'21-'22 Six Speaker
Those of you in the unlucky 2021-2022 6-speaker camp will have to steal their subwoofer amplifier signal from the left and right kick panel speakers. There really is no other way around it. Of course, certain amplifiers and kits made by companies such as @plugnplaykits can make this task substantially easier for you, but fundamentally it all has to come from the kick panels.
Factory Setup
With Subwoofer Upgrade (Proposed)
'23 Seven Speaker / '23 Seven Sub Delete
2023MY Broncos have all of the wiring in place for an amplifier, regardless of whether you have the sub delete option or not. Upgrades are as easy as taking the old amplifier/subwoofer out (or their fake equivalents), and installing the new amplifier and subwoofer.
Note the 2023MY Broncos with the sub delete option will need to use Forscan to turn on the subwoofer output from the ACM. This output will be a low level (aka: line level) output, not a high level (speaker level) output.
Factory Setup
Factory Setup - Sub Delete
'21-'23 B&O Package
The B&O package makes it tricky. The amplifier in the rear of your Bronco near the subwoofer is not just a simple amplifier. It is an entire digital signal processor (DSP) that also powers more than half of the speakers in your Bronco. That DSP talks to the factory Audio Control Module (ACM) over a digital connection using a protocol called A2B. Therefore you cannot simply replace the DSP with an amplifier.
There are several companies out there that have aftermarket equipment capable talking on the A2B protocol. BUT, if you are simply going for a factory subwoofer upgrade, your amplifier will have to daisy-chain off of the B&O DSP output.
Factory Setup
MY PERSONAL SETUP
I have a 2022 Bronco with the standard 6-speaker setup. To feed the subwoofer amplifier I am using a Plug-N-Play kit from @plugnplaykits. That kit steals the signal from the front kick panels, passes it through a load resistor to clean up the signal a bit and give the factory ACM something to look at, and passes it back over the wiring harness to a Kicker Key 500.1.
OTHER THREADS/VIDEOS...
These are thread I've come across that I felt were extremely helpful. If you got one I missed, link it and I'll add it to this list.
FACTORY WIRING DIAGRAMS
Hope that was helpful!!!
- [How-To] Factory Bronco Speaker Replacement
- [How-To] Amp Install - Kicker Key 200.4
- [How-To] FORScan Audio/Speaker Mods
- [How-To] Subwoofer Upgrade - Trim panel removal & Kicker install
2021 - 2023 B&O
- Voice Coil Impedance
- Speaker diameter & depth
- RMS power requirements
Speaker Diameter
- Amp: Kicker Key 500.1
- Sub: Kicker Comp RT 48CWRT84
SUBWOOFER ENCLOSURE
- Using a powered subwoofer. This has the amplifier, the subwoofer speaker, and the enclosure in a single unit. The Kicker Hideaway series is a popular example of a powered subwoofer.
- Using an external enclosure. This can be as simple as an standard subwoofer box you stick in your cargo area, an enclosure that mounts to your tailgate—such as the Stinger TXFBB12, or even a DIY box you built yourself.
- Mounting it to the factory location. Three options for this:
- 2023MY base audio enclosure - 170mm enclosure (~6.75")
- B&O enclosure - 200mm enclosure (~8")
- Aftermarket enclosure, such as the JL Audio Stealthbox.
POWER
Variant | Power from Battery | Power from Factory Wiring |
'21-'22 Six Speaker | Yes | No |
'23 Seven Speaker | Yes | Yes, but careful (12 ga. wire) |
'23 Seven Speaker (Sub Delete) | Yes | Yes, but careful (12 ga. wire) |
'21-'23 B&O | Yes | No |
GROUND
AUDIO SIGNAL
'21-'22 Six Speaker
Factory Setup
Factory Setup
'21-'23 B&O Package
Factory Setup
MY PERSONAL SETUP
- 2023MY Speaker/Sub Upgrade Megathread
- @jshapz - 2023 7 speaker subwoofer upgrade
- @cmcbronco - B&O sub installed on Base Bronco ….sorta….
- @John P. - John’s 2 Door Badlands Build (B&O Replaced with Active DSP)
- @Ksjrb03 - B&O sound system complete upgrade - Done
