How to get antifreeze/coolant reservoir cap off?
buzpro
Binky
Tacoma
How in Gods name do you get the antifreeze/coolant reservoir cap off? I can turn it 1/3 of a revolution to loosen or tighten it but it wont come off!! is there a new Ford trick to a simple procedure or what?
I need to top it off cuz its below min level.
Also, antifreeze is antifreeze right? I dont HAVE to get the Motorcraft one specd by Ford for a top off do I?
BlueBronco
DFW
'16 F150 KR - '21 BL - 23' OBX
Mine just screwed off. I recall having to put a bit of oomphf behind it but no tricks to removing it.
Also, I would consult the owners manual for the type of coolant as antifreeze comes in all sorts of different flavors these days. I topped off my Ecoboost F150 yesterday and that takes the orange dex-cool type but I think the Bronco was green if I remember right.
buzpro
buzpro
Binky
Tacoma
this is what is spec'd
Motorcraft® Yellow Prediluted Antifreeze/ Coolant (U.S.)WSS-M97B57-A2
i tried a lot of oomphf but it just wont budge past 1/3 revs
Bschurr
NY
do NOT mix different types of coolant - only use the specified antifreeze if topping up. Mixing incompatible coolants can cause radiator & cooling system damage!
(y)
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
Maybe it's like a child proof cap and you have to push down a bit before you can continue to turn it. I haven't checked my Bronco yet, but that was the way it has been on most of my previous vehicles.
buzpro
buzpro
Binky
Tacoma
I made the same assumption but @BlueBronco said his just screwed off .... I would hate to take it in just for a stupid fill cap issue
Side note:
Also I had it at the dealer 5 days ago and they didnt top it off as they claimed they top off all fluids as standard procedure
cigartexan
Jack
Boerne, Texas
1964 F100 SS - 2012 F-350 SD - 2021 4D Bronco FE
Mine spins off just fine, not a push and turn, just turn. It does have a felt audible 1 click when closed all the way, just 1 click please.
MayhemMike
Mercury
The coolant cap on my 2018 Mustang GT was a bear to get off. I actually stopped at the dealer and asked them to pop the hood on another Mustang so I could try and remove the coolant cap to compare it with mine. Turned out my cap was somehow torqued down hard. I suspect the same thing has occurred on your Bronco. Good luck.
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
use a pair of slip joint channel locks and get some leverage that way.
buzpro
buzpro
Binky
Tacoma
listening to all the input I think is somehow similar and i will have to do the same thing at a dealership
buzpro
buzpro
Binky
Tacoma
I thought about that but i dont want to break anything with unintentional force
JHawk
Ray
Heartland, USA
Fusion Sport
Take it to the dealer and let them open it or break it and fix it. Monitor the procedure in person
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
That's when the Ruskies were almost OK ....poor Vasily
Yeah. I know he would have liked to have seen Montana…..
