How to recalibrate speedometer for bigger tires?
MKE_Mike
Wisconsin
2022 Bronco Outer Banks
What are people using to adjust their speedometers when they go to a bigger tire?
V1Rotate
Brevard, NC
2022 Wildtrak
Mine actually got closer to accurate going slightly larger.. it was about 2-2.5 mph off (fast) at 60 prior
Felix808
SRV CA
FORSCAN, or there is a more expensive tool out there for the less computer savvy.
R1Bronco
R
Ford explore sport
I used Superchips Flashcal.Easier to use and cheaper....Turned off double honk and start stop also...Does others things too...
TallDude
North Seattle
2022 4dr
+1 for the Flashcal.
Got it off Amazon (https://a.co/d/6iUgWuE).
Recalibrated for some 35's on my BD (up from the stock size, ~31.8's) and it’s accurate within 1 mph.
Also disabled the double honk, start-stop and set TPMS warning light to whatever pressure I want.
MKE_Mike
Wisconsin
I just ordered the Flashcal. Thanks guys
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
37s on my sasquatch fixed mine. Was 3mph fast and now spot on.
Esmeral
Edwin
Miami
Tesla Model 3
I used flashcal to resize tires after installing a set of Sasquatch takeoffs on my non-sas BD. With the original setting (32"), my speedometer showed less speed than actual, like 3 mph less than the gps at 60mph. I set 34.5" (closest to 315/70/17) and now the speedometer shows 4 mph above the gps. The closest match is setting 33" in the device. Why could be that?
EJP-OB
Ed
@R1Bronco
How is the $200 flashcal cheaper than a forscan cable, $50, and a 1 year subscription, $12?
Heck, there's even a free trial version of forscan.
Unless you don't have a laptop, otherwise it's much cheaper and not hard to use at all. There are countless forscan threads with all the info needed.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
there's always the option of using the ford performance tune which includes tire size change as one of the minor capabilities
R1Bronco
R
Ford explore sport
@R1Bronco
I thought the year subscription was higher than that,but of course if you don't have a laptop then flashcal...
To me the flashcal was so much easier and straight forward ,plus my buddies were able to use it too,not sure if forescan let's you share....
If your good with computers, forscan....if not flashcal...
Aceinfinity1999
Jason
Middle TN
2 door Bronco black diamond.
What size did you calibrate it to?
