- Thread starter
- #16
I should’ve mentioned that. Obx was 2.7 as well.Assuming the Outer banks is not a Sas, and because the WildTrak is 2022 , which means no HOSS 3.0 goodies. So I'm not so sure about resale holding value on non 3.0 WildTraks going forward.
That extra 12,000 miles gets you gears, tires, rims, lift, not sure about engine - (you didn't specify if the OBX is a 2.3 or 2.7) which seems like a winner to me assuming the previous owner didn't ride that horse hard and put it away wet. But you will be lugging around a lot more weight, and you are planning on using it to tow, so there is that to consider.
But If they are both Sasquatch it's easy - pass, I don't see any benefit without the HOSS 3.0.
