Hey folks! I finally found the ideal solution for those of us who need to run a front plate with a winch and aftermarket setup with a front camera...
Innovative! My dealer drilled into my Bronco so I had to patch the holes...sigh...and in anger I threw that plastic bracket away.Lol.. i just took the free factory front license plate holder (that my dealer does NOT screw into brand new Bronco grills), flip it upside down and it fit perfect on my bumper.
Barely visible in the Front cam
That works! With my bumper hanging the plate below the fair lead would restrict airflow to my intercooler, so I was stoked that the setup I found puts My plate directly centered over the fairlead So it isn't blocking radiator air flow or intercooler airflow.Don't over think it. Just loosten the fairlead bolts enough to slide the upper edge of your license plate between the bumper and fairlesd, then tighten the fairlead bolts down to pinch the plate. When out doing serious wheeling , reverse the procedure to remove the plate.
see picture,
I initially had the Cascadia 4x4 Flipster, which also flipped up to expose the winch. With my camera relocation right above the plate, it limited the plate movement to just below horizontal when flipping it up...so the limitation was that if I had to winch from any position that resulted in the line being much higher than horizontal it would have thrashed the plate/bracket/line. Rather than risk that damage or having to unbolt the bracket and plate every time I needed to winch I went with the removable plate for convenience. Folks who don't need to relocate the camera can use a flip-up plate bracket with no risk of damage.The ARB Summit the license plate just flips up to expose the winch.
With the ARB it does relocate the camera but it is out of danger from the flip up plate. Same with the ACC module.I initially had the Cascadia 4x4 Flipster, which also flipped up to expose the winch. With my camera relocation right above the plate, it limited the plate movement to just below horizontal when flipping it up...so the limitation was that if I had to winch from any position that resulted in the line being much higher than horizontal it would have thrashed the plate/bracket/line. Rather than risk that damage or having to unbolt the bracket and plate every time I needed to winch I went with the removable plate for convenience. Folks who don't need to relocate the camera can use a flip-up plate bracket with no risk of damage.
Is it an all-in-one kit for camera and plate?With the ARB it does relocate the camera but it is out of danger from the flip up plate. Same with the ACC module.
Everything comes with the bumper. Camera relocate and plate kit.Is it an all-in-one kit for camera and plate?
Got it...if they don't sell that setup to folks without that bumper, the M2M/Stonsho is a solid alternative.Everything comes with the bumper. Camera relocate and plate kit.
