- Chris
- Mar 6, 2021
- 61
- 3,878
- 4,385
- Cold Spring, NY
- 2021 Bronco, 2020 Ranger
- Black Diamond
Whoops! I used the term frequency incorrectly. But, you picked up what I was putting down. I used a PNP harness, Iām pretty sure thatās how he wired it. Iāll give it a go and increase ever so slightly. Iāll report back.Yeah the Kicker Key effectively has two stereo amplifiers built into it. It depends on how you wire it obviously... BUT usually you would put the front two channels (the four speakers up front) on one amp, and the rear two channels (the two pods in the back) on the other amp.
Those gain potentiometers on the Kicker amp simply increases/decreases the overall volume. Doesn't do anything in regards to frequency. If you want more volume out of the rear pods you can simply increase the gain on the Kicker Key for the amplifier associated with rear two channels. And you should set the gain lastāafter both your Forscan mods and the Kicker auto setup.
Personally I have the gain for both amps (all four channels) set to their lowest setting so I don't blow out the kids sitting in the back seat. But if you don't usually have rear passengers... go crazy if you want more volume out of them.
