Install Power Heated Ford Seats after sale?
Bbaliatico
New Jersey
2022 Bronco
When I did the math between a base 4 door and a Big Bend it came to about 9K between a base with V6 and aux switches and a Big Bend with 4cyl and mid package. That really means I’m missing fog lights, power and heated seats and a grab handle. More or less as I am changing wheels and tires anyway.
but…I am wondering/looking for input as to the idea of buying the powerheated seats from Ford (depending on part cost) and installing in my base ‘22. When it finally gets here.
Any ideas?
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
You’ll spend more than the difference piecing it together
Laddyaddy19
Landon
North Dakota
Nissan Altima, Evo X, F150
Any ideas?
I bought some heated seat covers for about $40 on Amazon and really like them. They have lasted me 3 winters so far. They have to be turned on each time but they heat up almost instantly.
https://www.amazon.com/Zone-Tech-Travel-Cover-Cushion/dp/B09G79PHMZ/ref=mp_s_a_1_18?crid=S7XS5C3B20P5&keywords=heated+seat+covers&pscroll=1&qid=1642639554&sprefix=heated+seat,aps,157&sr=8-18&wIndexMainSlot=28
I’m guessing Ford heated seats would be more than the cost of the mid package. maybe they can be installed on the stock seats though. Following.
Ford Bronco Install Power Heated Ford Seats after sale? E649A7DD-6262-4CF5-AE34-F5AEFC0D9F5F
Papa Smurf
Jax, FL
The easiest and most economical thing to do would be to get a set of Katzkin covers with heat option. Those will likely cost around 2500-2800 with installation. Trying to add the power controls to move the seat will likely be a wiring nightmare.
Tricky Nick
Nick
St Charles, IL
2009 2dr JK, manual, AEV lifted, 35’s
My local top and upholstery shop quoted me $875 to install heating pads under my MGV front seats (see below), and said they could install the switches wherever I wanted them. That seemed too much for my tastes, so I may look into installing my self if it gets to the point I feel I have to have heated seats.
REMOVE AND INSTALL LEFT AND RIGHT FRONT BUCKET
SEATS....................................$875.00
REMOVE AND INSTALL CUSHION AND BACKREST COVERS AS NECESSARY
INSTALL SEAT HEATER ELEMENTS IN CUSHIONS & BACKRESTS
INSTALL SWITCHES ON SIDE SEAT MOLDINGS
INSTALL WIRING HARNESS IN VEHICLE AND REASSEMBLE COMPLETE
clarkT
PA & KY
2001 Mustang Bullitt
I’d guess the whole seat is currently unavailable to order (ask @flip).
I don’t mind the manual seat… it’s actually faster to slide back between my wife (all the way up) and me (all the way back) than my mustang that moves SO slow.
The heating pads themselves are cheap. Even from ford. My dealer said 200 a piece. But internet says the brand they use is less than half that…
The stock dash controls would get pricey because it’s the whole lower assembly. But if you are ok with using a different switch to turn them on, it’s simple.
Dealer didn’t seem to want to do the work so no idea what they’d charge. 1800 be my guess.
I was quoted 600 by an upfitter if ok using what they “normally” do and installing switch on seat or center console.
But if you are good with hog ring pliers and have a place to work, you could put in heated seat pads for under 300 bucks in parts.
Bbaliatico
New Jersey
2022 Bronco
Thank you all. I think you are right, I have manual on my jeep (sorry, it going) and other than up and down, it’s faster.
Had no idea about the wiring, I must have wrongly assumed most cars have the same harness for efficiency sake. Why make and install versions - more $$$.
I did get the auxiliary switches in case. I like cloth in a convertible tho so maybe I just get aftermarket under cloth and hook to the aux switches.
Production isn’t until Feb - supposedly, so some time to think about.
Thanks!
iwantabasebronco
No ones business
gmc
Heated seat kits are like $100 and you just wore them up like any other accessory. Just need to find a good place on the dash to mount the switches. The difficult part is removing the seat cover. There’s threads on this topic. Some good YouTube vids too
Ride Em Bronco
Al
Pittsburgh, PA
2008 Jeep Liberty Sport
I can't get Mid Package on Big Bend and still get manual tranny - so looked at YouTube and found video on installing heated seat pads:
