Installing Signature LED Tail Lights on our Base
EvanPeterson
Evan
Belvidere, IL
2021 Bronco Base/Sasquatch
Shattered my driver tail light on Trail 16, and local shop had a spare set of LED takeoffs laying around…
Did require FORScan flashing, but looks great!
Hkak45
K
Illinois
21 Bronco Black Diamond
Did you consider the Slim LED tail lights that Oracle sells?
Your bronco is looking good by the way! I'm going to try and get out on some more trail outings this summer with you all.
EvanPeterson
EvanPeterson
Evan
Belvidere, IL
Thanks! We have a bunch of trips planned, hope you can make it!
I actually ordered a set of the flush mounts, but Automotive Solutions had these sitting around from someone who’d switched to the Oracles, and I wanted to get it back to street legal as quick as possible. The flush mounts will be a better option still, because I’ll probably end up smashing the LEDs too 😂
Serrot12
Paco
Rowlett, TX
2023 Bronco
Saw your video on YTube. Could you ask what settings were modified using Forscan? I picked up a set of signature tails and would like to swap them out on my daughter’s Bronco.
Appreciate it
EvanPeterson
EvanPeterson
Evan
Belvidere, IL
Appreciate it
I will! Shop will be open on Monday, I’ll ask them!
Inlinejohn
WA
Several
But consider your taillights that stick out beyond the body, sacrificial elements to protect from more expensive body damage when this happens. This time you broke a light and it was an easy/quick fix. Next time with flush mount, you’re now into fender damage/repair…Just a thought
Cloak
Nate
2022 Ford Bronco Big Bend 4 Door
EvanPeterson
EvanPeterson
Evan
Belvidere, IL
Do you have any updates on this? I plan on switching to LED tail lights as well
Sorry, I forgot to reply, he said there was a tab where all he had to do was toggle back and forth between the two tail light options… said it took longer to start his computer than to sync
Cloak
Nate
Is there any chance you can post a video of them? Curious what the DRL looks like along with brake lights and turn signals coming from a halogen.
Blueberry OJ
Giancarlo
Riverside
2021 Bronco big bend 4D Non-sas, 2016 F150 3.5l EB
So I bought led tail lights for my halogen tail light BB from Alibaba. And they sent me this harness and they work perfectly. Not sure if anyone knows what these things they used are. But one wire also connects to the tail gate plug. Not sure why but they work great and only 300 bucks. Sorry didnt get a pic of the connector plugging into the tail gate behind the plastic piece but its self explanatory.
Ford Bronco Installing Signature LED Tail Lights on our Base 20230527_114741
Ford Bronco Installing Signature LED Tail Lights on our Base 20230527_124513
Ford Bronco Installing Signature LED Tail Lights on our Base 20230528_141620
Ford Bronco Installing Signature LED Tail Lights on our Base 20230527_124505
Ford Bronco Installing Signature LED Tail Lights on our Base 20230527_114737
Oscyy3
Oscar
Ford Bronco 2022 Sasquatch
Would you mind sharing the link?
Blueberry OJ
Giancarlo
Riverside
