Interior falling apart
MnLakeBum
MN and FL
‘18 Range Rover Diesel
Backordered item.
Use some 3M dual lock if the grill is back ordered. A 1” square of the dual lock in place of that broken clip will easily hold it in place.
Ford Bronco Interior falling apart 5A7AB6A9-48BB-495A-9970-CCF3D8F3F912
Smuck
Shon
Austin
32 Ford
Damn, were you rocking out hard core to some serious polka music?
SuperFord
2013 Ford Fusion
I took my old 2014 fusion in to have the rear speakers replaced before the warranty ran out because they were popping and i was told they were not covered under warranty, so I'll be replacing the stock ones in the Bronco as soon as i get it.
your speakers are definitely covered under your “bumper to bumper” 3/36 warranty. Your service tech and/or advisor were full of shit.
Now extended warranty, maybe or maybe not depending on your coverage/policy level.
Razorback
Dallas
Lincoln MKX
One of two things:
1) Too much base and broke the clip. Who needs B&O right???
2) You waxed it didn't you?
Nothing else is possible given the flawlessness of the rollout.
BroBronco
N/A
Ford Bronco
If you do this, make sure you get the industrial strength with red backing on the adhesive side. Otherwise in heat the weak adhesive will fall off. Also suggest prepping the surface with an alcohol wipe before applying velcro locks.
Sandbergo
Jelani & Dave
Orlando
Rogue
Ford Bronco Interior falling apart 1632360758850
Bullitt
Colorado Springs, CO
2022 Bronco, 2001 Bullitt Mustang
I read the subject title...and then I saw the photo. I about died laughing. #dramaqueen
MnLakeBum
MN and FL
Alcohol wipe is recommended and I’ll normally rough up the plastic substrate with a scotchbrite as well. The adhesive is good for temps up to 220* and I’ve never had it fail in an automotive application.
Amcap76
Amcap76
2018 F250, 2019 GT-350, 2004 Jeep LJ
These posts drive me insane. Shit breaks on every vehicle. PERIOD. This not a new phenomenon.
Right. Parts falling off while driving down the road on a vehicle with less than 3,000 miles on it happens all the time.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
It’s a speaker grill, get over it. Take it in, have it fixed.
dwbronco
Manchester, NH
2018 F-150 King Ranch
So, this just happened. Driving along and I felt something hit my foot and fall behind the clutch pedal. I came to a stop and found the cover to the speaker in the kick panel had broken off and came loose.
Ford Bronco Interior falling apart at-first-i-was-like-serious
I'm not sure I see this as the "interior falling apart."
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
OP when you depress the clutch do it slow and steady. Then let it up smoothly. If you flail your feet around like a tap dancer on meth you might break the speaker grill.
MayhemMike
Mercury
I have noticed in my F 150, that after I have been driving it for an extended time, the seat under my butt is extremely warm. BTW, fess up, you kicked it with your foot more then once prior.
