Interior Lighting Manual Activation
BlueBoy
Martin
CA
1989 Bronco 351W
UPDATED Thanks to Dadsquatch and WhiskeyCity's quick response, I located the button near the map lights and my upfitter switches. (Answered)
Has anyone figured out a way to turn on the interior lights manually? Older cars there was either a button by the headlight switch, or you would even twist the headlight switch all the way to the right. This would also help out for the aftermarket IAG interior lights or the Mabett rear dome light replacement, WITHOUT having to wire a trigger to an upfitter switch. @Ford , if your listening, this could be a simple over-the-air (OTA) update to include a virtual button on the dash touch screens to activate the inrerior lights and Bronco owners would appreciate it!
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
The button is up by the front lights....like right next to them.
WhiskeyCity
Shannon
Bardstown, KY
2023 Bronco Badlands Sasquatch 2.3L, 7spd
I have the upfitter switches and the interior lights are activated by a button up by the map light by the switches.
BlueBoy
BlueBoy
Martin
CA
1989 Bronco 351W
Thanks, did a search in my digital owners manual and it showed where. Senior moment, I appreciate the quick response
