Lsm7581
Ram 1500
Having been unhappy with the interior lighting of the Bronco, I upgrade the interior lighting using Govee LED under lighting kit. https://www.amazon.com/gp/product/B0969PDDP5/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 and wired it to Aux 6 Switch. The default setting is white but it can also be set to any color or sync with music( I will never use that feature, but is there for those who want a disco Bronco). I couldn't be happier with the results, its like daytime in the car when I turn them on. I can also dim the lights using the Govee app but for the most part I never have the need to open the app. The default white full on works for my purposes. Hard to beat for $50 in parts and a little sweat equity.
The whole process took be about an hour an half to wire. I used the Aux 6 switch and wired it to the rear white/orange aux wire in the passenger side rear. I had to remove both covers of the air roof air bags to fish the wire along the roll cage (yes, made sure to secure the wire to not interfere with the opening of the air bags) to the rear cover of the roll cage. The covers are the only trim pieces secured with bolts. The rest of the top trim and side trims are all held in place with body clips. I pulled down the rear roll bar trim piece to store the LED driver/Control and fished a wire down the passenger side pillar to tie into the Orange/white aux wire. I stuck the lights on above the airbags on the soft top front brackets using 60lb double sided tape and the rear lights on the rear roll bar just behind the passenger seats. The install is clean and you hardly notice the lights until they are on.
I couldn’t stand the lack of light in the stock soft top, so I followed this tutorial today. Definitely took longer than him, but overall super happy with how it turned out. Lights are wired into aux 6 for now. I ran all of the wiring behind the dash or behind the roll bar air bags. In passenger glove compartment it is wired to brown/white and shares a ground to the right side of the head unit with a spade connector
Ford Bronco Soft top interior lighting upgrade 7BF4E8F8-7B75-42D9-BF95-149443DAFC49
Ford Bronco Soft top interior lighting upgrade 48D46DD5-8EB4-4E05-BEED-228F5B69BDDE
Ford Bronco Soft top interior lighting upgrade 7EADF61D-7001-4116-B893-9A3636673C20
Ford Bronco Soft top interior lighting upgrade 89CAE8E5-D793-4311-B587-016488E915EE
Ford Bronco Soft top interior lighting upgrade DCD733B4-3974-40B1-A992-288FAC2845EC
Ford Bronco Soft top interior lighting upgrade B50C4170-966A-4763-A70F-A147365CA73E
bytheway
Brice
Louisville, KY
MrGreen55
Kyle
Oregon
toyota scion xb
I was think about doing this same thing but different location with Baja Designs lights found one that should work perfect. only should need 1 light for the 2 door.
Ford Bronco Soft top interior lighting upgrade 01_P04_ANG_A__77388.1654558684.1280.1280-1280x1280
Lsm7581
Lsm7581
Ram 1500
Lsm7581
Lsm7581
Ram 1500
Those look nice! Do they wire to switch or is that a button on the light?
MrGreen55
Kyle
Oregon
toyota scion xb
Both was thinking about putting right between the factory lights were that hole is and tapping into that power if it's possible.
buzpro
Binky
Tacoma
NICE ... especially like the red hue ... can it go blue as well?
Hey can you show the way you did the wiring? also, are the lights on both driver and passenger side or just the passenger as its shown in the pics?
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
Lsm7581
Lsm7581
Ram 1500
Yes there is a phone app so you can make it any hue and have it change colors. I did both driver and passenger, so 4 lights total. The one I bought came with 6 so I may add 2 more to the cargo area. I didn’t take many pictures during the install, but here’s a few that I just took. I put the light controller in the glove compartment, I still need to clean that up some but ran out of time before my husband got home with my kids. I connected the red wire from the controller to the brown/white wire in the glove box. I connected the ground wire to an existing ground behind the head unit. From the controller I ran the passenger side wires by removing the body panel next to the grab handle, 3 clips, just pops off. From there I ran the wires under the black weatherstripping, undid the airbag panels with 5/16 socket. Slid the light behind the airbag and into the b pillar. Attached the front one with mounting tape on the bracket that’s there. To get to the back corner I removed the rear airbag panel and pulled down the cover underneath it just enough to slide the wire in. Rear panel just pops off. Followed the same thing for the drivers side, other than the wire wasn’t long enough for the rear driver side. So I spliced the wire and made a connection under the B pillar. To get from glove box to drivers side I fished the wire right behind the screen, there’s just enough room there.
I also blew the fuse for aux 6, so the fuses for it are in the engine compartment. Fuses 60-65 are for the aux switches. I think the one that blew was 65.
I hope that makes sense.
Ford Bronco Soft top interior lighting upgrade 5E39E7A5-531D-4FBF-B973-7C9B9B32F98E
Ford Bronco Soft top interior lighting upgrade CD54B4AF-7431-47CA-A993-F3DADE50DC0A
Ford Bronco Soft top interior lighting upgrade D66EE455-A2E8-473E-9022-95911D43464D
Ford Bronco Soft top interior lighting upgrade 477A8067-B8A2-4AF8-9141-7FD2D27874B7
Ford Bronco Soft top interior lighting upgrade AD343BDF-DAD5-4FE3-B8B2-F44B2DB37F69
Ford Bronco Soft top interior lighting upgrade 5C4F5A57-CB6C-49E9-BDBA-EFA2E8D85318
Ford Bronco Soft top interior lighting upgrade 2912C55B-C4DC-4EAD-8049-2CF6067F422E
Ford Bronco Soft top interior lighting upgrade 9F67D69F-324A-4FCD-A70B-E24548E4C40D
Ford Bronco Soft top interior lighting upgrade 7CC3D404-E07B-4693-9BF1-48F7EF8B29B7
Ford Bronco Soft top interior lighting upgrade 296EB51A-A523-4FAD-A160-57E79A128886
Ford Bronco Soft top interior lighting upgrade 2AB37B6E-CA18-49A3-BF0A-FDF40DCEFF9C
Lsm7581
Lsm7581
Ram 1500
Please update me if you do this! Would much rather it tap into the factory lights.
MrGreen55
Kyle
Oregon
toyota scion xb
will that my be 2 year wait at this point someone else that has bronco would be able to find out faster then me :censored:
TowBoater
2019 F150
Those are the govee lights correct? That came from the post you had commented on?
BrentC
Brent
Calgary, AB
OP, tell me about the climbing wall behind your pictures! Is that at your home? Bouldering or taller?
Also, great job on the lighting - the soft top definitely needs more and I’ll be doing an upgrade at some point.
Lsm7581
Lsm7581
Ram 1500
Nice catch! Kids bouldering. It was actually a gift for my older son a few years ago. We’ve moved a few times and are now in a rental house and don’t have room for it so it’s just in garage storage. It’s just 3 panels of 4x8x3/4 plywood.
thanks, it’s was a fun project and the kids love all the color options
Ford Bronco Soft top interior lighting upgrade 9FE37B2F-32C9-42A2-BEBD-45E4A987DA02
