Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼
Leafy
Jon
Nh
2024 2 Door Badlands, Manual
Are these short/partial intakes quieter than the full length ones that eliminate the resonator box?
Does this intake require you to remove the whole box to change/clean the filter like some of the bronco intakes?
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Haven’t cleaned it yet, but pretty sure you unscrew the lid and pull it out
Leafy
Jon
Nh
Alright that’s good. Really would love to go with this intake to get the Donaldson power core filter, just want to make sure I’m not sacrificing on getting the most turbo noise and having an annoying filter cleaning.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Quick question, when I go to clean my dry filter, just wash with water and dry, or do I need soap (and if soap, which kind?)
Dialtone
Twilight Zone
Bronco Big Bend Mid
Wet or oiled I've used a cleaner. K&N type cleaner for oiled and just plain dish soap for dry filters. I use an old paint brush to lather it up some. Anything with stiffer bristles had a tendency to fluff up the filter material. Kinda like link. So any scrubbing I do is always on the input side of the filter which is always the nasty side anyway. This might not even be an issue with these filters. I have no experience with that manufacturer
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
And if I got a filter sock on it?
Dialtone
Twilight Zone
Bronco Big Bend Mid
Not really a difference
A pre filter, in my understanding, is intended for larger particles than the main filter. I have never seen pre filters oiled. Even K&Ns pre filters weren't oiled. I honestly haven't looked at the pre filters in a long time so I could be wrong about the oiling. When I worked construction many years ago I ran them on my truck. Even when I used plain old paper filters. They did their job. Pull it off, whack it against a tire to get the big chunks off and put it back on. Yes, I did actually wash it occasionally (y)
I don't see oiled foam filters mentioned here much. I ran a Uni foam filter for more than a decade on my MINI and never had an issue. Dirt bike guys loved them.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Ford Bronco Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼 IMG_7914
Could I still use this or would I be asking for trouble
