- Mitch
- Apr 7, 2021
- 91
- 291
- 998
- St. Louis, MO
- Website
- www.pandamotorworks.com
- 2021 Ford Bronco, 2014 Fiesta ST
- Outer Banks
2.3L Bronco Closed Box Intake From Volant Performance with 3 Filter Options!
Volant's cold air intake unlocks added performance from the Ford Bronco 2.3L EcoBoost engine along with added protection giving you confidence that your vehicle is not only getting the added benefit of an aftermarket intake, but also that it is protected from the harshest environments while exploring the world around you. Volant's Ford Bronco cold air intake with free-flowing DryTech synthetic filtration is perfect for maximizing your performance gains while minimizing your maintenance concerns for on-road daily driving. Each intake comes with a pre-filter protective cover that adds hydrophobicity to your filter for added protection, but still allows uninhibited air flow. On top of keeping your filter dry, it will also keep your filter free from mud, sand, or any other debris resulting in greater filter longevity.
Filter Options
PowerCore Filter
Not all filters are created equally, as they are purposefully designed to cater to the environment they will be used in. If you plan on taking your Bronco Offroad, then this is the filter choice for you as the PowerCore provides maximum filtration by filtering out microscopic debris that filters can't. These filters also provide 100,000 Maintenance Free Miles!
Perfect for the Frequent Offroader
Drytech Dry Filter
The Drytech DryFilter is the perfect filter who are after a filter that provides the performance gains of a traditional cotton gauze media with the simple maintenance of a non-oiled filter. This filter offers up to 50,000, after that maintenance is as simple as can be using just soap and water! No oiling required!
Perfect for the Daily Driver
MaxFlow 5 Oiled Filter
The MaxFlow 5 Oiled Filter is designed for those looking to get the most performance possible from their filter! The trade off with the added performance is the required maintenance of this filter as it does require regular cleanings and reapplication of filter oil.
Perfect for those seeking Maximum Performance
The Volant Performance is not only a great addition performance wise, but it also looks great in the engine bay! If you are looking to pick up a Volant Performance Intake, you can do so using the link HERE!
Filter Options
PowerCore Filter
Drytech Dry Filter
