Good write up , but where's the 2.7L analysis ? Assume these are all on Map 7, but did you do any dyno pulls on other maps you can show? (i.e. I run Map 5 or 6 and would like to know what those figures look like).
Love to hear it! Thank you for your support! #PandaArmy #PandaBroncoJust ordered mine. @Caleb@PandaMotorworks thank you for the detail you provided, it really helped me decide. As for the super in-depth analysis demands... for a $600 bolt on, I'm more than happy to let my butt dyno be the judge
Super in depth demands? Since when is asking for dyno stats (that they already have) an unreasonable REQUEST for an engine tuning product on a 60k vehicle? It's literally the defacto standard in tuning.Just ordered mine. @Caleb@PandaMotorworks thank you for the detail you provided, it really helped me decide. As for the super in-depth analysis demands... for a $600 bolt on, I'm more than happy to let my butt dyno be the judge
Sounds like we may need to get this and then post the real graphs when we take it to our real dyno.this reminds me of the DTE boost module from the raptor before the real tunes came out....
I have a few questions...
which sensors does the module communicate with?
what is the change in boost pressure from stock-map7?
what effects do the higher boost pressures have on intake temps?
what are the plugs gapped to and what tool do you use to check?
the dyne graphs you posted have a sept 2021 date stamp, why the long delay in posting these graphs?
We use data from the MAP sensor. The Panda Power software module processes in real time and then transmits the optimized data to the sensor in your vehicle. The result is a considerable power boost you can feel – by automatically increasing the boost pressure, adjusting timing, and fueling. To increase the boost pressure, the turbine RPM is increased within a range defined by us, which increases your engines efficiency level. This provides more air for the engine, which allows the ignition timing to be adjusted more precisely and makes combustion in the cylinder more effective.this reminds me of the DTE boost module from the raptor before the real tunes came out....
Hi everyone - any new updates on this from everyone’s experience using it? I have a 2.3L (manual) and I hope to install it over the weekend. I also have 35s and new wheels, so I am hoping to see some extra juice 🧃
