Is there a lift on a base Sasquatch Bronco?
ibock
Dallas
2022 2 Door Bronco
Forgive me I know this has been discussed before but I am seeing mixed answers. I have a 2022 base Bronco that I just purchased that has the Sasquatch package. Does this Bronco have a lift on it? If so, what's the lift? Will 37s fit on it without rubbing. My tires are in great shape but I was just wondering for the future.
I am on a tight buget but want to make my Bronco not look stock. Any suggestions?
BlueBronco
DFW
It has the larger bilstien coilovers (known as Hoss 2.0) compared to the hitachis that come stock on non-squatch Base, BB, BD and OBX. So yes, in that sense it has a "lift.". But no, 37's won't fit.
Wheels and tires are usually the best way to differentiate from stock but not very budget friendly. Since you have the Squatch wheels already (which I happen to like) consider changing the color of the beauty rings to set yoself apart via powder coat, paint or plasti-dip
Oldhippie
Barry
Santa Cruz, Calif.
Sasquatch is a 1” lift to fit 35s…37s require another 2”-3” lift and crash bar mods for no rub. congrats on your bronco…
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Honestly, if you're committed to differentiating yourself from stock, get the 37's then work on making them work. I assume you'll need some lift (maybe the Bilstein coil upgrades?), but really, it's put up or shup up when you get that far.
Fmuguira
Frank
Idaho
Jeep TJ
Unless you re wheeling hard or really after the “look” I can’t see the 37” s being worth the squeeze over 35@ s in my mind.
Maybe I ll think different when the GYs are worn out ….
Definitely has impact on suspension, tie rods, mpg/power ….
Coastalcop
3rd Coast
You don’t specify how “tight” your budget is so here’s a rough idea. Figure 3k plus in tires and sus mods for 37”. And a MPG drop. At 4ish a gallon for fuel, will the increased expense cause you hurt?
cheap? Throw an Amazon bull bar on the mod bumper ( I can’t remember if sas comes with mod bumper). Or takeoff mod and bull bar. Under 1k easy “bill bullbar with headlight wrap around was about 200 bucks on Amazon last I checked.. Plastidip beadlocks, Harbor freight ditch lights ( they will bolt directly to the mount points 50 ish bucks and ok lighting. Mudflaps , about 125-150 Amazon mybatt.
PCDan
Dan
Park City
1968 Ford Bronco
Being “On a budget” and doing 37s properly is a mutually exclusive proposition lol …
put on some aftermarket wheels and it won’t look stock, but it won’t look a lot different than the 1000s of others out there.
kevin.gt
Kevin
Canton, GA
Check out this thread. I believe smaller 37’s can be stuffed in there with sas wheels, no lift, no rub with 1/4” wheel spacers
PCDan
Dan
Park City
1968 Ford Bronco
Yes we’ve all seen his posts. He must think there is an award for saying he has no rubbing 🏆🤪 … but for trips to the mall is just fine. Trust me, 37s will rub … even with a lift.
Twister22
michael
lone jack,mo
2012 Raptor 1965 Mustang 1968 Mustang
Badlands with sasquatch package. I used a Readylift 3" lift and went with 18x9.5 Black Rhino wheels and 37" Yokohamo MT
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
Why? Where are you going that 35" won't do the job?
ibock
ibock
Dallas
2022 2 Door Bronco
I just like the look of bigger tires, but I think at this point I cant justify spending the money. I like the idea of changing the wheels down the road.
