Is there a 1.25” level kit for Sasquatch?
Brock9281
Rob
Atlanta
Exactly what the title says πŸ˜‰
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Out of curiosity, why not just 1”?
MWILD
2022 - BB Sasquatch - Mid - 2.7L
Should be a 1.5” leveling kit available from Rough Country pretty soon.
rtaylor
R
ID
19Raptor, 22Bronco
Max of 1" using simple spacers. Minimum of 1.5" using bolt-on spacers.
If you really need 1.25", then combine 0.39" rear preload spacer from Zone F1301 kit with upper 0.185" spacer and lower 0.26" spacer from Rough Country 40300 kit.
1.5 * (0.39 + 0.185 + 0.26) = 1.25"
You could also try fitting in an extra 0.185" RC spacer (not sure if bolts long enough). That would give 1.5 * (0.185*3 + 0.26) = 1.22". See photo - probably won't work with stock nuts.
Ford Bronco Is there a 1.25” level kit for Sasquatch? 1645676409520
bishop0577
Robb
Corvallis, OR.
2021 Bronco 4 door base/sqatch
That forward rake bugged the hell out of me. The first mod I did on my Basesquatch was the Zone One 1" leveling kit. Bolt on kit that took about 2 hours to install. 1" was perfect and gave it the stance it should have had out of the factory.
zedster
Bill
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Same here. Zone 1" worked great. After is on top. Before is on the bottom.
Ford Bronco Is there a 1.25” level kit for Sasquatch? 20220205_074528
Ford Bronco Is there a 1.25” level kit for Sasquatch? 20220204_091313
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Gen2 Raptor Midtravel / TowRunner F250
when deciding which height of "leveling kit" to get please don't fail for forget the rear weight. If your running around town with no rear doors and or no hardtop, ther rear will sit higher.
I plan on spending most of the time in my bronco with the top off and doors removed, my first step will be to measure the pinch weld rails nearst front and rear tire to gauge homuch height I need from the front suspension. Im anticipating closer to 1.5" on without the top, what do you all think?
Ftchmup
WI
23 Bronco, 20 F-250 Tremor
Concerned there will be too much gap though with keeping 35s
1)
Ford Bronco Is there a 1.25” level kit for Sasquatch? 8675B2B4-7DB9-4E6C-8E57-FB9DB724503F
Ford Bronco Is there a 1.25” level kit for Sasquatch? 976C2E0C-743B-4FC5-B8BC-3977EBE8C212
RPG perch collars with stock wheels and tires. On a Wildsquatch.
2) stock
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
2) stock
You installed the smaller perch collar just in the front, correct? Why go with this vs a spacer lever like the Zone? Is one easier to install, or better than the other?
I am debating this option for my Badlands.
Ftchmup
WI
Cl
Claims are 2 1/2 front 1 inch rear. I did both. Mainly to accept 37’s. That pic was the same day as they were installed
I liked it because it didn’t add a bunch more hardware like the spacer kits do. I have no experience with spacer kits. Can’t say they are good or bad. Just my opinion. Install it was not hard, but you have to have a spring compressor.
BigGarnet
β€˜21 Bronco
I wish someone would put out replacement springs for Sasquatch...I haven't seen them yet, but having having had IFS trucks before, that is by far the best way to level the front. Just a little bit stiffer spring lifts the front...and generally improves handling too.
