Max of 1" using simple spacers. Minimum of 1.5" using bolt-on spacers.Exactly what the title says
Same here. Zone 1" worked great. After is on top. Before is on the bottom.That forward rake bugged the hell out of me. The first mod I did on my Basesquatch was the Zone One 1" leveling kit. Bolt on kit that took about 2 hours to install. 1" was perfect and gave it the stance it should have had out of the factory.
Concerned there will be too much gap though with keeping 35sUse the rear perch collars from RPG on the front, thatw will give you the desired lift
1)Concerned there will be too much gap though with keeping 35s
You installed the smaller perch collar just in the front, correct? Why go with this vs a spacer lever like the Zone? Is one easier to install, or better than the other?1)RPG perch collars with stock wheels and tires. On a Wildsquatch.
2) stock
Claims are 2 1/2 front 1 inch rear. I did both. Mainly to accept 37βs. That pic was the same day as they were installedYou installed the smaller perch collar just in the front, correct? Why go with this vs a spacer lever like the Zone? Is one easier to install, or better than the other?
I am debating this option for my Badlands.
