- First Name
- John
- Joined
- Mar 22, 2021
- Threads
- 42
- Messages
- 2,334
- Reaction score
- 2,943
- Location
- Charleston SC
- Vehicle(s)
- 2021 Bronco 4dr OBX MIC 2.7 Rear Locker A51 Roast
- Your Bronco Model
- Outer Banks
40,000 miles and nearly 2 years on my 2.7 in an OBX. Yes, it is a bit "rough" at lower RPM when not under load on 87 octane gas. Hit the road, and the gas, let the turbos kick in, and that sputtering is forgotten. I have found that, as you wrote, that 91 or 93 octane makes it smoother running, and also increases mpg by 1-2 mpg. Very nice, reliable engine. Had the 2016 version of the 2.7 in my previous F150, and it was similarly reliable and flawless. I change the oil every 5,000 miles.First.. background on me…. I’ve built a few v-8 engines for street and drag… tuned tubo rotaries in RX-7s and two carbureted 360 swaps into jeeps…. So.. this isn’t my first rodeo!!!!!
ANYWAY…
Just got our Bronco last week, black diamond 4 door with steelies and the 32”all terrain tires, I wanted the 2.7 all the way the 4 just seemed like it was wound too tight!!!
BUT……After a week and 400 miles, I’ve noticed that the engine isn’t as smooth as I thought it would be.
It’s not acting up (at least I don’t think so… but that The point of this thread.)
It idles kinda rough… especially at cold start….. I put high test in it and that helped a but..
It’s noisy, lots of belt noise and i swear it sounds like my Harley where you can hear the valve train, and there’s definitely injector pulse making itself known.. way louder in front of the car than our pacifica with the 6 cyl pentastar..
It’s lumpy…. At take off, if your not on the throttle hard, it kinda seems like you can feel each piston firing until you get up to 2k… From my turbo experience though, its not surprising, lower compression with no boost at low throttle and new turbos that are still tight tend to feel a bit lumpy….
I also know its tuned for torque and im not used to mud tires anymore….
My wife….. who knows nothing about engines except how to put her foot down…. Does hear or feel a thing!!!!!!! But me… i’m like…. Eeehhhhhhhhh i dunno!!!!!!
But……..I just wanted to know if this is all normal, or there’s anything i should be lookin out for!
