JCR Offroad Pinch Weld Covers
decummins
Daniel
New Hampshire
2022 Bronco Wildtrak
I really dislike the look of the exposed pinch weld. So I added JCR Offroad Pinch Weld covers.
These are powder coated black steel plates that bolt through the pinch weld. I was a bit surprised at how heavy and thick they are. The only complaint I have though is that I had to re-use the two front factory painted bolts. JCR provides replacement black bolts but the heads are too small and require a washer that was not provided.
Ford Bronco JCR Offroad Pinch Weld Covers IMG_2401
Ford Bronco JCR Offroad Pinch Weld Covers IMG_2402
F OR D
BD Green Machine
Let them know they are great and will probably set you straight.
If not, they can tell you the length/thread/pitch and you can order a few black bolts.
Klink
Pennsylvania
2013 f-150 FX4
I installed these last weekend. Want to mention in addition 2 the (small) problem with the front 2 bolts, you have to loosen the 1st two bolts on the factory steps as well for clearance. Simple install. Hope they don't make the pinch welds rust quicker...
decummins
decummins
Daniel
New Hampshire
Yep. I only had to do that on one side.
