I purchased and mounted running boards. I don’t like the way it looks with the holes showing. Anyone else do this? Is there grommets or something to make this look better?
I am confused. Does this cover the exposed area or is this a different option for side rails?I used these:
https://accessories.ford.com/FordUS...ance-kit-5-door-side-lh-rh-door-fender-rocker
https://www.airdesignusa.com/2021-2022-bronco-appearance-kit-set-rear.html
Not cheap but looks great. Applies with 3m tape and includes pinch weld cover. All plastic, looks factory, and protects paint. If you go this route, it is easy to install but following instructions exactly. I did not, had to remove 3m tape on several pieces (not easy) and buy/reinstall new 3m tape. Had I not rushed and taken shortcuts, would have been cake. Make sure to use 3m adhesive promoter and buy extra on amazon. It comes with some but the stuff is magic for doing a great job applying all things with adhesive.
I used these:
Do you have any pictures of yours installed that you can share?I used these:
