Jeep tailgate table for Bronco
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I've been waiting to see if anyone releases a tailgate table with both an extension board and a Molle system and found this one for a JL/JK. Has anyone mounted a Jeep table to a Bronco? Visually, they both look pretty similar so I'm hoping it would work. This checks all the boxes for me...
https://bison-gear.com/en/home/86-drop-down-tailgate-table-.html
I'll measure this mounting template this weekend to see how it lines up and hope that the rest fits well.
Ford Bronco Jeep tailgate table for Bronco Zrzut ekranu 2022-07-22 o 10.10.38
rtazz17
Connecticut
2022 Ford bronco big bend
Looks like it would. I have put a few things made for jeep on my bronco. Much cheaper too and fits. Im over this bronco upcharge for everything.
UtahBrandon
UtahBrandon
Brandon
I ordered one so I'll report back. My guess is that I'll need to drill a couple of holes in the mounting plate but that shouldn't be a big deal.
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Following - this would be a good adder. Good luck on the install!
TavisB
Pa
22 ManSquatch, 10 F150
I'm pretty sure the Rough Country fold down table is the same for Wrangler and Bronco.
da_jokker
Jeep Wrangler JKUR
I'm drawing a blank right now with which table I ordered, but a specifically ordered one that had the same part number for both a JK and a Bronco so I can move it over once I get my WT.
Many require holes to be drilled so I would think most likely you can drill holes wherever needed to fit either.
UtahBrandon
UtahBrandon
Brandon
I got the table in from bison-gear and aside from predictable issues with fitment, it’s pretty awesome. $211 for the product and $79 shipping from Poland. Took 9 days from order to delivery
Ford Bronco Jeep tailgate table for Bronco 1C7C873E-E40B-4816-A40D-6E57C6D35A52
Ford Bronco Jeep tailgate table for Bronco 138CB03C-A098-4240-8C2F-9F95CBE2DF7C
Ford Bronco Jeep tailgate table for Bronco CC5F334D-372D-4C97-A79C-FC7C0C21D872
Still working on how I’m going to mount it but I think I’ll need to drill one hole in the bracket and two holes in the tailgate for four mounting points. Additionally, the recess in the wood table will need to be trimmed a bit to clear that tailgate protrusion.
UtahBrandon
UtahBrandon
Brandon
I installed the table this weekend. I decided to use two existing tailgate holes at the top of the bracket, circled in blue. I inserted two 1/4x20 stainless rivet nuts there and used two 2" stainless screws to hold the top. For the bottom, I drilled two holes in the tailgate to accept 1/4x20 stainless rivet nuts and used two 1" stainless screws. I didn't modify the mounting bracket at all and used existing mounting slots as there's quite a few to choose from.
The table is solid and doesn't rattle at all. Interesting that they used paracord for the hinges and it seems to be solid. My gut said to change that to a stainless cable, but after thinking about it, I don't think I need to do that. The slide-out wooden extension was a little too large to clear the tailgate protrusion (what is that thing called?) so I had to trim that wood back around 1.5-2" to clear.
Ford Bronco Jeep tailgate table for Bronco IMG_4718
Ford Bronco Jeep tailgate table for Bronco IMG_4711
Ford Bronco Jeep tailgate table for Bronco IMG_4712
Ford Bronco Jeep tailgate table for Bronco IMG_4715
Ford Bronco Jeep tailgate table for Bronco IMG_4720
‘21OBX
90Bronco19
2022 bronco outer banks
Very nice! My ford one that was on it already (I bought a mannequin) the lower right hinge rattles like mad. It’s going in to have an axle shaft replaced so I’ll inquire if they’ll warranty it or not.
Felix808
SRV CA
How dare you avoid the Bronco tax. :p
(Good on you (y))
Donkeygyrl
Sheri
San Francisco
Bronco on order
Rockslide engineering, took all of 20 min to install made for a jeep, fits perfect zero rattles my grill fits perfect.
Ford Bronco Jeep tailgate table for Bronco 20220810_152225
Ford Bronco Jeep tailgate table for Bronco 20220810_152303
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
I wonder if Bison Gear is working on a bronco one 🤔
da_jokker
Jeep Wrangler JKUR
I bought this exact one for my Jeep because I knew it was the same part number for the Bronco.
Plus I like the fact that it basically comes with two shelfs and that bottom shelf comes out really far once you open it up
sko
Tomasz
Denver,co
elantra, have dep on a badlands
I dont think Broncos are on sale in Poland; Unless some of the newly available ones In the UK made their way there. I do like the idea of supporting a Polish business (as I'm from there myself) shipping looks hefty though, however a similar table like this is 500+ that I've found.
FellowM3
Northern NJ
I contacted them and they said they do sell a table for the bronco..but its branded goose gear.
So I checked their site and they sell the goose gear table. Same exact table, same hinges, which apparently are proprietary .
It could mean goose gear buys all of their tables from Bison.
Whats annoying is the tax we pay for Bronco gear.
  • Like
Reactions: sko
