Just ordered wheels! Am I nuts?
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
I really want Mickey Thompson 33x12.50R17 Baja Boss ATs, but I'm a little nervous about that wide a tire fitting on a Black Diamond without a lift.
I got 285 75/r17s. Toyo ATIIIs
Thats ~34” but only ~11.25 wide. Should fit Badlands nicely.
MoabRox
MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
Nice wheels and great tires! They'll look great on your BL.
I like the Baja Boss ATs in the 33x12.50R17 since they have a D load rating, but if they are too wide, I'll go with the LT315/70R17 Es.
accord77
joey
PA
18 acura tlx awd
@MoabRox very nice but I will order my rims once I have a delivery date also newly made tires
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
I waited for the 35mm offset to be back in stock. We gotta post pics. Let people see the different offset on the same wheels.
kodiakjack
Brett
Alaska
BMW X-4, Toyota Highlander, Bronco OBX
I love SCS (Stealth Custom Series) wheels. Am considering the Ray10's for the Bronco. They are typically made for Toyota but the bolt pattern is same as the Bronco. Only issue is the center bore size, I think a center ring adapter should do the trick. Now figuring out the offset...I am also considering Method 310 Con 6, maybe Fuel Revolvers or American Racing Baja. I want to go for a retro look on Bronco.
I looked at the sizes and the Bronco has a 93.1 mm wheel hub and the Ray 10s have a 106mm wheel center bore. Just need 93.1 to 106mm Hub Centric Rings.
Question: does it matter if you get nylon or aluminum on hub centric rings? I figure the metal is stronger but I have never felt with them before.
JCAntimatter
Long Island, NY
19 4Runner TRD PRO, Acura MDX
Nylon is fine.
Ford Bronco Just ordered wheels! Am I nuts? 400B94B2-4396-4305-AE83-75741BDB8263
Discount Tire
Arizona, USA
discountti.re
All Things FORD
As @JCAntimatter noted, Nylon would work. In fact most of the Hubcentric rings we carry are actually plastic.
This is due to the purpose of the hubring is not to carry any load, simply to help during installation to center the wheel onto the the studs. Once the lugs are tightened down the hubring serves no purpose.
