K&N Air Filter
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
okbob
North of the Red
71' u15, 66' u14, 66' u14
Not of fan of oiled air filters with turbos, OEM filters all the way on turbos, both diesel and gas engines.
airishfan
rob
North Las Vegas
jeep cherokee
If you live in areas that has lot of dust the oil air filters not the best . lot of people think they ok in the dust but if you think about they have small holes to help the engine breath better by letting the air get in and the dust . Look on Jeep forums and see how many people find that out .
BroncoAZ
Mitch
No, thanks. K&N filters are garbage on modern vehicles. They were fine for carbeurated cars back in the day, and I ran them on my 1987 Bronco, 2001 F-150, 2005 Nissan Titan. On anything with a mass air sensor they have caused me problems regardless of how careful I was oiling a removing the excess.
Ford does a damn good job of designing the intake system to support all the power the engine is capable of.
da_jokker
Jeep Wrangler JKUR
Performance air filters, including drop in ones do flow more air (in arguably letting more dirt).
But the key is if your engine needs more air flow. Most manufacturers intake systems flow more than enough. You take off Bronco engine that has at least one turbo and I think you'll find that the CFM requirements are not being limited by the stock intake.
What really helps is making sure to get cold air, not more air. However that requires exposing the intake to more elements which is not something you want to do on an off-road vehicle. (Fine for mall crawling)
This does not apply, once you start upgrading your engine to a point where it requires more CFM, But unless you're planning on upgrading your turbos, are installing a tune that's going to the dump much more fuel, I don't see this happening
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
Yeah, just to agree with what has already been posted. It has been conclusively shown that a good paper filter flows slightly more then an oiled cotton filter, and an oiled filter can mess with modern engine control air metering sensors. Oiled cotton filters are a no go, no point whatsoever in a modern vehicle. K&N usually offers a choice of cotton or paper filter, if you think you really need an aftermarket intake, or go with another brand.
JFelty
Minnesota
Mustang Mach E
I have been running a K&N intake and filter on my 2014 Taurus SHO for all of its 97k miles and never an issue. I will have to rethink using one on my Bronco IF/WHEN it ever arrives. The SHO hasnt spent too much time off the pavement and I an sure the Bronco will :)
BroncoAZ
Mitch
I’m glad it’s been working for your SHO. My 2005 Nissan Titan was very sensitive to oil getting on the mass air flow sensor and causing a slight misfire. I was very diligent with the oil, taking care not to apply too much, then using a leaf blower to suck air through the filter and using a clean micro fiber cloth to remove any excess oil. Every time I cleaned the filter I had the same issue and had to use a cleaner on the mass air flow sensor a couple days later to clear the misfire. At one point I removed the intake tube after the filter and noticed a fine coating of reddish brown sludge when I wiped it out with cheesecloth. My buddy’s Titan with similar mileage and a stock paper filter had no sludge. That was the day the oiled filter went in the trash.
The Volant Powercore filters made by Donaldson are the only aftermarket filters I would consider running these days.
