Looks like K&N has an air filter for the full size Bronco. I looked at the Roush and at $400 plus I thought I would try this first. https://www.stage3motorsports.com/e-0634-21-22-bronco-kn-replacement-air-filter.html
I have been running a K&N intake and filter on my 2014 Taurus SHO for all of its 97k miles and never an issue. I will have to rethink using one on my Bronco IF/WHEN it ever arrives. The SHO hasnt spent too much time off the pavement and I an sure the Bronco willYeah, just to agree with what has already been posted. It has been conclusively shown that a good paper filter flows slightly more then an oiled cotton filter, and an oiled filter can mess with modern engine control air metering sensors. Oiled cotton filters are a no go, no point whatsoever in a modern vehicle. K&N usually offers a choice of cotton or paper filter, if you think you really need an aftermarket intake, or go with another brand.
I’m glad it’s been working for your SHO. My 2005 Nissan Titan was very sensitive to oil getting on the mass air flow sensor and causing a slight misfire. I was very diligent with the oil, taking care not to apply too much, then using a leaf blower to suck air through the filter and using a clean micro fiber cloth to remove any excess oil. Every time I cleaned the filter I had the same issue and had to use a cleaner on the mass air flow sensor a couple days later to clear the misfire. At one point I removed the intake tube after the filter and noticed a fine coating of reddish brown sludge when I wiped it out with cheesecloth. My buddy’s Titan with similar mileage and a stock paper filter had no sludge. That was the day the oiled filter went in the trash.I have been running a K&N intake and filter on my 2014 Taurus SHO for all of its 97k miles and never an issue. I will have to rethink using one on my Bronco IF/WHEN it ever arrives. The SHO hasnt spent too much time off the pavement and I an sure the Bronco will![]()
