Loving the new ZROADZ slider steps.
stanger1944
kevin
Lower Arkansas
98 F150, 16 F150, 2010 Mustang GT
Just ordered. 4 to 6 week lead time.
Really hoping it’s sooner.
They told me the same and then they shipped like a week later. Ordered 4/20 delivery 5/6
mbagne
Matt
Placentia, CA
Mach-E GT
The little ones (6, 7, & 8 ) were having a hard time getting in and out without a boost so I made them help me install some new rock slider side steps this evening. Loving them. They are my favorite look aesthetically. I'm sure they'll offer some protection from pebble pings. They'll definitely offer some door-ding protection. Super easy to install (if you are removing the factory rails). Took just a little over half an hour and that was with the kiddos helping. ROCK SOLID sturdy. Absolutely no play or movement at all with my big ol' body hopping up and down on them. The kiddos can easily get in and out without any help at all.
Look nice. How difficult is it for one person to put these on without help? Seems like it would be difficult holding them level while trying to bolt on, unless they first "hang" on the underside before bolting.
idobleedblue
idobleedblue
4-door Badlands Sasquatch Bronco
While I had the kids help on one just so they could have a sense of ownership and pride in helping... the other one I did by myself.
Get two 5-gallon buckets from Lowes or Home Depot, turn them upside down and set the rails on there. Crawl underneath. Be careful, because if not they could slip and fall on you which would hurt. But if you are careful that should hold them just a few inches away from where you need... enough to hold one side up while you bolt it on... then hold the other side up while you bolt it on. It wasn't too bad at all.
BRBlue
Houston
Toyota Tundra
I like mine but be advised I went through 3 different sets and they never lined up with the factory bolt holes. The 2nd set I received had significant cosmetic paint defects and the 3rd set had dents. I finally gave up on the 3rd set and used a reamer to drill out the front mount holes so I could get the bolts to fit. Figured they would eventually get banged up so I was ok with the dents.
mbagne
Matt
Placentia, CA
Mach-E GT
Perfect, thank you!
JonDW29
Jon
NoVA
'16 F-150
The 5 gallon bucket trick is a good idea. I used a hydraulic shop stool to get them to the right height. Balanced them on there and got the rocker panel screws in to get it started. Would have definitely been easier with a second set of hands, but it's doable solo.
If you don't have the Ford rock rails, make sure to order their additional mounting kit. It's easier to install the sliders first, then slide the upper mounts in.
That sucks that yours came with issues like that. Did you buy direct? Mine came in great shape, with some pretty serious packaging. I did need to ream out one of the rear mounting holes with a dremel (best tool I had on hand, took a while lol) to get everything to line up.
BRBlue
Houston
Toyota Tundra
Yes, I bought direct. Had to stay on customer service but they at least shipped replacements. They were packaged well with foam but were still dented in a couple of spots.
Johnnybuck2
Johnny
2022 bronco badlands Sasquatch
man I ordered these steel legs for a table project. Dude it had tire tracks on it and it was bent like a taco at one end. You never know what you’re gonna get.
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
Installed the factory mudflaps yesterday. Some interference with the zroadz. I put a heat gun on the flap to take care of it.
Can you explain more about what you did to get them to fi? Looking to do something similar with my ZRoadz.
RUZ
Arkansas
2006 F150, 2020 QX80
I used a heat gun to sofen the mud flap, pushed them against the steps until the looked right. It didnt take much.
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Can anyone confirm if these will work with 37s? I know the factory rails need trimming to clear.
