Mabett Bronco LED "Raptor" Grille Lights Fit Bronco Badlands / Wildtrak / First Edition / Everglades Available Now!
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Buy "Bronco LED "Raptor" Grille Lights" directly for $35.99 via this link: https://www.amazon.com/gp/mpc/A37Y6NXWFSL813
  • Note: Please return to this page to redeem the discount after the promotion starts on 2022-8-30 12:00 PDT​
  • Note: Please operate when “Bronco LED "Raptor" Grille Lights” is available
PARAMETER
  • Voltage: 13.5 V​
  • Current: 0.1 A​
  • Power: 1.35 W​
  • Color temperature: 1500-1700 k​
  • Single bead power: 0.2W​
  • Lumens: 135 lm​
PRODUCT DESCRIPTION
  • Fitment: Fit Ford Bronco Badlands / Wildtrak / First Edition / Everglades.​
  • Application: Always on when the power is turned on, turn off after turning off the power.
  • Installation: Comes in a pack of 3 lights and the plug-and-play wiring harness for a simple install, no drilling required. The operation process is shown in the video.
Kayci77
BC
4-door Badlands
I'm getting the ' All eligible products for this promotion are currently unavailable' message. Did I miss out?
niterider006
State College, PA
Looks good but I wish I could find a way to get them on when my parking lights are on. The current fuse position turns them on when the ignition is turned on. I believe I have to use fuse #55 but that's a 30amp fuse and only a 10amp tap-a-fuse came with it.
PatientlyWaiting
Brent
Marietta GA
MY22 Wildtrak
Which fuse did you install them on? The instructions weren't that clear. It looked like an empty fuse right in front of #25. I couldn't get them to work in that spot. Did you add it #25 and just replace the fuse that was already there?
I ended up using #63 which is Aux #4. I don't have anything installed on that switch so it works for now.
niterider006
State College, PA
I used #22 which is the front camera. I don;'t think there is even a connection point in front of 25. Yes, the point is to replace the current fuse with the tap a fuse.
Ford Bronco Mabett Bronco LED "Raptor" Grille Lights Fit Bronco Badlands / Wildtrak / First Edition / Everglades Available Now! 1664893509033
